Latest post Tue, Apr 23 2019 1:22 PM by jef. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Apr 12 2019 6:12 PM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,409
    • Points 41,135
    Problem linking a renamed MXF file.
    Mac OS 10.4.1  MC 2018.11
    Long story short - I made a Op1a MXF file.  Linked into the project that created it to check it.  All good.
    I then renamed the file.  Tried to link into the project I had exported from.  Got a “can not create AMA mapper” sort of error.  No way to get it to link.
    Went to another room, made a new project.  The renamed file linked just fine.  Went back to the original room, renamed back to the original file name.  Now the file will link.
    I am betting this has something to do with AMA logging?  Whatever, it is not good.
    Jef
    Jef Huey
  • Mon, Apr 15 2019 6:52 AM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Melbourne, Australia
    • Posts 88
    • Points 1,080
    Re: Problem linking a renamed MXF file.
    As you didn't mention it specifically, I have to ask, did you delete the linked file from your Bin and try a new linking process?
    I've had similar issues to that same process (using linking to check an exported file) and deleting the link and linking anew worked for me.
    OS 10.11.4 Mac Pro Media Composer 8.6.3 with Symphony & Interplay 3.4 AvidFX 6.4 Neat Video 4.1.4 ISIS5500 [view my complete system specs]
    Neil.
  • Fri, Apr 19 2019 12:26 AM In reply to
    • jef
    • Maryland
    • Posts 3,409
    • Points 41,135
    Sorry - wrote a response and guess I never hit send.
    Yes I did try deleting the linked master clip and relinking - multiple time.  Once, when I did this, the new linked clip actually showed the original file name from before the rename!!.
    Jef
    Jef Huey
  • Tue, Apr 23 2019 4:12 AM In reply to
    • N Ryan
    • Posts 88
    • Points 1,080
    jef:
    ...I did try deleting the linked master clip and relinking - multiple time.  Once, when I did this, the new linked clip actually showed the original file name from before the rename!!.
    Jef
    Ah! That jogged my memory. I THINK that you need to delete the AMA Database.
    I'm not near a system at the moment, to be able to tell you where it resides but I did find this location from another post:
    luca.mg:
    ...wrangling the c:\Users\Public\Documents\Avid Media Composer\AMA Management\AMA Metadata Folders might fix the problem.
    I believe you can delete the whole AMA Management folder - I've done that in the past - but have a read of this Avid advice, too:
    http://avid.force.com/pkb/articles/en_US/how_to/How-to-disable-AMA-Managed-Media-to-increase-performance
    Neil.
  • Tue, Apr 23 2019 8:53 AM In reply to
    Yes the AMA media databases can be a real pain.
    The biggest regular issue I see is users AMA link to a removeable drive to test a file.
    All good so they move the file to local storage and relink.
    All good. But check the source path for the file and it points to the original first AMA link.
    A nightmare when it goes to conform.
    Diable AMA managed media it offers little.
  • Tue, Apr 23 2019 1:22 PM In reply to
    • jef
    • Maryland
    • Posts 3,409
    • Points 41,135
    Good advice Pat.
    Jef Huey
