Latest post Fri, Apr 5 2019 8:40 AM by luca.mg. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Apr 4 2019 11:16 AM
    Can't find the ERA Voice Leveler - how I start it up inside Avid MC?
    I have installed his free loyalty reward product, however I can't find any way to actually use it inside Avid MC.
    I imagined it would be an audio effect that I'd drop onto an audio track but I can't find it anywhere.
    Can anyone enlighten me?
  • Thu, Apr 4 2019 12:14 PM In reply to
    Re: Can't find the ERA Voice Leveler - how I start it up inside Avid MC?
    It's in the Audio Suite. Open the Audio Suite window, there you will find it,
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Thu, Apr 4 2019 12:51 PM In reply to
    Thanks very much for your response.
    Unfortunately, when I went to the Audio Suite, these are the only options I see...
    That is, I can't see any sign of the ERA Voice Leveler.
    Is there something I'm overlooking here?
  • Thu, Apr 4 2019 1:49 PM In reply to
    You do not overlook anything, ERA Voice Leveler should be in this list. I guess something went wrong during the installation process.
    I am sorry I cannot help you further and hope, someone else can do it.
  • Thu, Apr 4 2019 2:28 PM In reply to
    Okay, thanks Roland, appreciate you trying to sort this for me, have a good day :-)
  • Thu, Apr 4 2019 2:35 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,875
    If the plug-in installed then it would be located in the c:\Program Files\Avid\AVX2_Plug-Ins directory. If it's installed anywhere else then you won't see it.
    Dave S.
  • Thu, Apr 4 2019 3:13 PM In reply to
    Thanks Dave, the plug-in had installed into the default location, which is C:\Program Files\Steinberg\VstPlugins\Accusonus.
    I wasn't aware the Avid plug-ins need to be installed into C:\Program Files\Avid\AVX2_Plug-ins, there certainly doesn't seem to be any instruction to do this in any of the documentation.
    I'm seeing the Voice Leveler in Audiosuite now though.
    Thanks again to you both for your help Smile
  • Thu, Apr 4 2019 3:23 PM In reply to
    In my case, the plugin installed automatically into C:\Program Files\Steinberg\VstPlugins\Accusonus. And it works.
  • Thu, Apr 4 2019 3:30 PM In reply to
    Makes me wonder whether I did something else wrong too!  Still, all's well now Smile
  • Thu, Apr 4 2019 4:59 PM In reply to
    I'm not familiar with this plugin but MC does not support VST plugin format. See if the installer has an option for Audio Suite or AAX (ProTools based).
  • Thu, Apr 4 2019 5:03 PM In reply to
    Location of 64 bit AAX plugins
    C:\Program Files\Common Files\Avid\Audio\Plug-Ins
  • Thu, Apr 4 2019 8:47 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    Other than in the AudioSuite, if correctly installed the Era plugin is available as a real time audio effect in the "Audio track effect tool", "Mono dynamics" submenu. As a side note, I own two perpetual licenses, but only received one serial number for the Era plugin, anyone here has multiple licenses, and if yes, how many Era serial numbers did You get?
    peace luca
  • Thu, Apr 4 2019 11:26 PM In reply to
    I got one for each of my licenses, Luca. Are you sure both your licenses are under active support? J
  • Fri, Apr 5 2019 5:48 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    Hi Job and thank You for Your time. Yes, both licenses are active, renewal due in november.
    peace luca
  • Fri, Apr 5 2019 8:40 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,582
    • Points 65,470
    It's me again, the second serial came in late! Good day to everybody.
    peace luca
