Latest post Thu, Aug 15 2019 12:39 PM by astrogeorge. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Mar 20 2019 9:05 PM
    • mnbkyle
    • Joined on Tue, Sep 15 2015
    • Minneapolis, MN
    • Posts 46
    • Points 545
    Sorenson Squeeze Alternatives and Compression Workflows
    Hey all-
    Just curious what some of your compression worfklows are now that Sorenson Squeeze is out of the picture. Our finishing workflow used to be outputting a Quicktime Reference file, import the QTREF into Sorenson, assign a preset, "squeeze", and then continue working within AVID on another task while the compression is happening.
    With Sorenson gone, we are forced to output a fullres file from Avid (which locks up the application) and then import that file into Adobe Media Encoder.
    AME gets the job done, but it's the additional time and storage space that has increased and decreased our efficiency.
    Anyone have any alternative compression software that accept QTREF? or any other efficient workflows you'd like to share?
    Thanks!
  • Wed, Mar 20 2019 9:48 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,400
    • Points 17,285
    Re: Sorenson Squeeze Alternatives and Compression Workflows
    Adobe Media Encoder CC2017 (and before) accepts QTRef, CC2019 does not.  If you have a CC account you can download CC2017.  They co-exist perfectly well.
  • Wed, Mar 20 2019 10:00 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,227
    • Points 14,710
    TMPGEnc Video Mastering Works supports QTREF
    MC 2018.12.7 (+Symphony)/BCC2019 12.5.2/RED 5.6; BlackMagic Ultrastudio Mini Monitor+Recorder (11.4); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz... [view my complete system specs]
  • Thu, Mar 21 2019 5:34 PM In reply to
    • mnbkyle
    • Minneapolis, MN
    • Posts 46
    • Points 545
    Good tip - but I downloaded AME 2017 and get this error messag when dragging in a QTREF. Not sure what else I could be doing wrong. See below for my QTREF specs
  • Thu, Mar 21 2019 5:38 PM In reply to
    BenoitM:
    Does TMPGEnc support higher frame rates? One limitation of Squeeze was it was limited to 30fps
    Looking for a solution that will convert 50i into 50P with fields into frames.
  • Thu, Mar 21 2019 10:27 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,227
    • Points 14,710
    Yes, it does many frame rates ! (the long drop down list goes from 1 to 120 fps, with many non-integers.)
    and it does fps conversion if needed
    (you also have the choice for the deinterlacing method; 50i to 50p is an easy one)
  • Thu, Aug 15 2019 12:39 PM In reply to
    You can set MC up so it exports directly to media encoder. I done it years ago if you google or post on here someone will help you set it up
