Latest post Tue, Mar 19 2019 5:01 PM by Terry Snyder. 7 replies.
  • Mon, Mar 11 2019 2:22 PM
    Cannot import MP4 clip
    I got an MP4 clip from a client.  I can play it on my system but iy won't import or AMA link.    I tried bringing it into Squeeze to transcode to a format MC will accept, but I get an error message that it is "Not a format supported by Squeeze."   I'm confused, because if it will play on my computer, I assumed my system had the appropriate codec?  I've looked online and there are a bunch of ads for converter software.   Wondering which one is the best for the price?
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Mon, Mar 11 2019 2:28 PM In reply to
    Re: Cannot import MP4 clip
    I just found out from the cameraman they are original Sony MP4 files.
  • Mon, Mar 11 2019 2:37 PM In reply to
    In the Source Browser, what does it say under the Plug In column? Does it link if you choose a different plug in?
  • Mon, Mar 11 2019 2:46 PM In reply to
    camoscato:
    It says "Can't Be Linked"
    Camerman said they are XAVC files from a Sony A7.   I import XAVC from my Sony FS7 all the time, but the files from the A7 are in an MP4 wrapper, which is evidently what the A7 uses.
  • Mon, Mar 11 2019 3:35 PM In reply to
    If you click on "Can't Be Linked" do you get any choices from the drop-down menu?
    Terry Snyder:
    http://www.nablet.com/products/plugins/avid-media-composer/xavc-s-ama-plugin/
    That plug-in should work (there's a demo version), but it's not free. If you google search "link a7 mp4 avid" you'll get a bunch of forum posts with suggestions about other ways to go about this.
  • Wed, Mar 13 2019 2:12 PM In reply to
    camoscato:
    Terry Snyder:
    The cameraman was kind enough to export the clips I needed using H.264, which MC could import.   He did this in Premier.   While MP4 is still not considered a high-end professional format, more and more cameras are using it and it's frustrating that Avid requires the purchase of an $89 third-party plug-in while Premier can handle it easily...and for free!
    But at least for this project, problem solved.   Thanks!
  • Fri, Mar 15 2019 11:13 PM In reply to
    Yeah, I know these clips. They are HEVC. For some really annoying reason, AMA does not do HEVC unless you buy an additional plugin. I drop them in Adobe Media Encoder and export them as MXF keeping all the metadata and timecode.
    If you open these clips in VLC and check the codec, you'll see HEVC somewhere fur sure.
    Grtz, Wim
  • Tue, Mar 19 2019 5:01 PM In reply to
    Wim Schalley:
    This format is becoming more popular.  I don't shoot with any cameras using HEVC, but this is the second time in as many months that I've received footage using this format.
