Latest post Mon, Mar 11 2019 4:07 PM by CHL. 4 replies.
  • Sun, Mar 10 2019 5:01 PM
    • CHL
    • Posts 35
    • Points 495
    MC 12, AJA T-Tap, and split audio output
    I recently got the AJA T-Tap to monitor to an older FSI 2450 monitor.  The mini audio output from the FSI is terrible!  I wonder if that's the way it is or if my mini jack is damaged?
    Is there anyway to split the audio to output via the computer and video out to the T-Tap?
    Thanks!
    MC 6.0.1, Mac OS 10.7.3 MacPro 5,1, 8 cores, 2x2.4 Ghz Quad, 17GB RAM [view my complete system specs]
  • Sun, Mar 10 2019 5:23 PM In reply to
    • Ryan Johnson
    • Joined on Tue, Dec 12 2006
    • New York, NY
    • Posts 36
    • Points 465
    Re: MC 12, AJA T-Tap, and split audio output
    To my knowledge there's no way to split audio/video playback between different devices, but this would be a great feature.
    We have T-Taps in all of our rooms, and we used to use the de-embedders built into our JVC video monitors but they're awful. We've since installed spearate SDI audio de-embedders for this exact reason. The Blackmagic SDI to HDMI converters are pretty cheap, and they include stereo analog audio outputs which sound way better than the JVCs. Still, it's another part to buy and replace if it fails.
    -Ryan
    MacPro's, OSX 10.12.6, MC 2018.12.1, Nexis [view my complete system specs]
  • Mon, Mar 11 2019 3:30 PM In reply to
    • CHL
    • Posts 35
    • Points 495
    Which converter are you using?  I can't seem to find a BM SDI to HDMI with seperate audio out?  I did find a SDI to Audio out which is about $200.
    I called FSI and over the phone they said the board could be the issue and it costs $395 to replace and I would have to pay shipping both ends.  Not sure if I should fix it or patch the problem by adding an adapter.
  • Mon, Mar 11 2019 3:58 PM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 272
    • Points 3,590
    https://www.blackmagicdesign.com/products/miniconverters/techspecs/W-CONM-26
    i'm using this - split audio, convert to hdmi, passthrough sdi , and also applies two 3d luts (lut box for cc)
    my zoo: NEXIS Pro 40 tb sw v18.6.1; MBPro_late_2013 15'' i7 16GBram OSX 10.12.6 MC 2018.12.1 BMD US monitor (or AJA io XT ), EXT thunderbolt NvidiaGPU... [view my complete system specs]
    DJFio[DB]
  • Mon, Mar 11 2019 4:07 PM In reply to
    • CHL
    • Posts 35
    • Points 495
    Thanks!  I may just go with this.
