Latest post Mon, Apr 22 2019 3:51 PM by Marianna. 9 replies.
Page 1 of 1 (10 items)
  • Wed, Feb 27 2019 3:11 PM
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    MultiGroup in 18.12.1 creates one clip not multiple
    This is in 18.12.1.
    I haven't used MultiGroup since 18.7 or maybe 18.4 and selecting a bunch of clips and selecting MultiClip will create a bunch of separate Group clips and a MultiGroup clip.  It now creates one clip with a dot in front of the name.
    According to the Help file, this is the expected behaviour:
    "Your Avid editing application creates several group clips for each take in the bin, and then creates a multigroup clip from the groups. The multigroup clip has the same icon as the group clips, but the icon is preceded by a plus sign."
    Avid Media Composer 2018.11 / MacOS High Sierra / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
  • Wed, Feb 27 2019 3:37 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    Re: MultiGroup in 18.12.1 creates one clip not multiple
    Went back to 18.11 and MultiGroup works.
  • Wed, Mar 6 2019 9:37 PM In reply to
    • Geoffs
    • Joined on Mon, Oct 19 2009
    • L.A
    • Posts 88
    • Points 1,080
    I can confirm we're seeing the same thing. 18.12.1 is currently unuseable for this reason. We get one master group, but none of the subgroups.
    Windows 8.1 Professional 64bit i7 4600K 3.2 32 gig-o-ram GTX TITAN Video Card 17" Macbook Pro i7 8 gig-o-ram [view my complete system specs]
  • Thu, Mar 21 2019 1:09 AM In reply to
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    Has anyone reported this to Avid support as a bug?  Would like to see this fixed.
  • Wed, Apr 17 2019 2:34 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    So I see that 2018.12.2 has added a "Multiple Groups" checkbox in order to create... multiple groups, which is good.  But I am seeing group clips being created with only one clip, which doesn't make sense.   So now I have to prune the results of MultiGroup of all these single clip group clips.
    http://resources.avid.com/SupportFiles/attach/README_Avid_Editor_v18.12.2.pdf
  • Mon, Apr 22 2019 1:48 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    I rolled back to version 2018.11 and MultiGroup doesn't create group clips consisting of one clip, which is the good and expected behaviour, so this must be a 2018.12.1,2,3 bug.
  • Mon, Apr 22 2019 3:01 PM In reply to
    • Posts 10,666
    • Points 223,900
    Chuckkahn.....
    2018.12.2....
    In Media Composer releases prior to 2018.12, if you used the MultiGroup function, it created several group clips for each take in the bin, and then created a MultiGroup clip from the groups. This way, you could create multiple groups with matching Timecode, without having to identify the clips with matching Timecode manually.
    Starting with Media Composer 2018.12 the MultiGroup function only creates a MultiGroup clip in a bin with all the clips. No group clips with matching timecode are created. In some instances, you might want multiple groups created rather than the MultiGroup clip. With this release, you have this option. Select the clips, right click and select MultiGroup. Enable Multiple Groups. When this is checked, multiple groups are created instead of a MultiGroup clip.   see attached.
  • Mon, Apr 22 2019 3:09 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 362
    • Points 3,990
    Yes I realize all that from above but the issue/bug I am raising is that MultiGroup in 2018.12.2 and 3 with the Enable Multiple Groups option selected, is creating group clips consisting of one clip.   For example, let's say for simplicity's sake I have a bin with the following three clips:
    take 1 a camera
    take 1 b camera
    take 2 a camera
    Selecting all clips in bin (all three above) MultiGroup with Enable Multiple Groups will create two group clips, one group of take 1 a and b camera and another group of take 2, just a-camera -- which is totally redundant and not in keeping with 2018.11 and earlier behaviour.
  • Mon, Apr 22 2019 3:36 PM In reply to
    • Posts 10,666
    • Points 223,900
    Got it Chuck....
    Creating a case and getting this looked at.....
    Stand by
  • Mon, Apr 22 2019 3:51 PM In reply to
    • Posts 10,666
    • Points 223,900
    Chuck and Geoff
    I created cases for you and actually reproduced it myself.
    Stand by for support.
