Latest post Sun, Mar 3 2019 9:15 PM by Supermandan1. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Feb 26 2019 12:03 PM
    Transparency
    I want to make an animated title to be used as part of a design in Titler Pro.  I've looked at numerous ways, including GIMP, to create this, but just cannot figure it out (GIMP's method of structuring frames for an animation is inappropriate to my design in mind).
    The video to be loaded onto the MC timeline plays a mandala spinning, with its four concentric circles turning anti- & clockwise individually.  Presently, on video, the near-white of the mandala spins against a near-black background.  I want to make this black background into a transparency.  How to do ?
    Also, the export file size has to be small (a few MBs at best) so as to input into Titler Pro. Albeit I'm guessing the final rendering in TP6 will bring the whole down to something manageable?
    Thank you,
    DC
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Wed, Feb 27 2019 9:48 AM In reply to
    Re: Transparency
    Hi, can anyone help on this one ?
  • Thu, Feb 28 2019 9:02 AM In reply to
    Re: Transparency
    Really... anyone, please ?
  • Thu, Feb 28 2019 3:42 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Re: Transparency
    The easiest way would be to key out the background in TP6. Note that it's probably easier to do if you also replace the black background with a solid green or blue background, otherwise you might inadvertantly alter any black lines in the actual graphic.
    Please look at the TP6 doc's for how to key out color information.
    Dave S.
  • Thu, Feb 28 2019 3:58 PM In reply to
    Re: Transparency
    Ok, I will explore this option.  While we're here, though, how to do this in MC ?
  • Thu, Feb 28 2019 6:12 PM In reply to
    Re: Transparency
    Supermandan1:
    MC is not the best tool for building an animated title. If someone has given you a graphic on a black background and you want the background to be transparent, your best option is to go back to them and ask for the graphic to be made on a transparent background (an alpha graphic).
  • Thu, Feb 28 2019 6:16 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Re: Transparency
    MC is notriously bad at exporting files with Alpha channels. Depending on the version of MC, you may be able to get one out as DNxHD or DNxHR, and I think TIF image sequences may support them, but that's about it. I do all my FX work in other applications, so if I'm dealing with sequences from MC I green screen the background (in other words, the bottom track is nothing but a green backgroound, and anything I key out above shows it) and export the mixdown. Then I color key out the green is whatever else I'm using.
    Dave S.
  • Thu, Feb 28 2019 6:18 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Re: Transparency
    camoscato:
    Or what Carl said!!
    Dave S.
  • Thu, Feb 28 2019 6:54 PM In reply to
    Re: Transparency
    Ok, thank you.  I have contacted NewBlue, we'll see what comes of it.  I thought I had read somewhere that you can apply a mask and somehow 'transparency out' the surrounding of the circle.  In theory this sounds relatively easy, but it's the result that counts.
  • Sun, Mar 3 2019 10:38 AM In reply to
    Re: Transparency
    Hi, NewBlue came back and their solution is surprisingly simple & effective. Thank you, DC
  • Sun, Mar 3 2019 2:53 PM In reply to
    Re: Transparency
    Supermandan1:
    That's great! Are you going to share it so if someone else comes across this thread they'll benefit?
  • Sun, Mar 3 2019 9:15 PM In reply to
    Re: Transparency
    Hi, yes.
    Specifically, I am looking to mask off the outer edges of a spinning manala (circle), so the details may slightly change for other people's requirements.  In essence, in TP it is Add Shape > Ellipse.  Then in the Style tab add your colour/gradient/photo/image.  Then in the Effects tab hit the drop-down and select Mask. Then play around with the options that then pop up under Blending Mode and see what works best for you.
    D.
