Latest post Thu, Feb 21 2019 9:36 PM by Marianna. 2 replies.
  • Thu, Feb 21 2019 5:09 PM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,373
    • Points 40,745
    Insert File Export tool issues
    MC 2018.11  Mac OS 10.12.6
    I have been beating on this tool, trying to decide whether it is safe to use during delivery to networks.  I have had issues.
    First, on my home system which is limited to El Cap OS I can not get it to work at all reliably.  Now testing on a system with Sierra, it is working BUT I am getting some errors.
    First, I took a show that I had output to MXF OP1a DNx 145 and changed about 5 Slates in the show.  This seemed to work well.  I tested the resulting file in MXF4mac player (RIP), Premiere 2018, Resolve 15 and it looked great.
    When I attempt to link back to this file in Avid I get:
    Exception: Cannot create the AMA sample mapper to play this clip - SelectFileMob() failed. OK
    What????
    So I did a bunch of test trying to recreate this error.    I made new MXF OP1a file and just started making small changes and linking back in Avid.   All of these worked just fine until I deleted audio in the same area where I was making a video only change.  I selected Use Marks and Use Selected Tracks in the Insert Edit Export menu.  I only had video tracks selected with my In and Out marks.  I did the edit.  After Avid was done making the fix, the following error message popped up:
    AMAMapper::Setup() floc is set to NULL.  OK
    Avid was not happy linking to this file UNTILL I quit and restarted Avid.  Then all was good.  The fix had worked as I wanted it to.
    All of this is to say I am nervous in using this tool for critical deliveries.  And all deliveries are critical!!
    I have started other threads on this tool and get little to no response.  Which surprises me based on the incredible value this tool presents.  I feel like I am just calling out “Bueller”.
    Jef
    Jef Huey
  • Thu, Feb 21 2019 6:19 PM In reply to
    • jef
    • Maryland
    • Posts 3,373
    • Points 40,745
    Re: Insert File Export tool issues
    Ok, an update of sorts.
    I decided on a whim to check the first problem file in a different suite.  It linked with no issues!!  Back to my room.  Still no good.  Restart Avid.  No good.  Finally a full power off, power on of my system. POW! Now it works.      ???
    So that is good news.  But I am still a little gun shy of this tool.  Would love to hear that someone else is using it in a real delivery situation.
    Jef
    Jef Huey
  • Thu, Feb 21 2019 9:36 PM In reply to
    • Posts 10,159
    • Points 217,400
    Hey Jef
    Let me get one of the work flow peeps on this. I do know that El Cap and the higher 2018.x versions dont like each other - hence better performance with Sierra and even better will be seen with high Sierra.
    Stand by
    xo
