Latest post Sun, Feb 24 2019 7:18 AM by dew. 3 replies.
  • Sun, Feb 17 2019 2:50 AM
    • Due South Films
    • Joined on Thu, Nov 11 2010
    • Christchurch, New Zealand
    • Posts 26
    • Points 315
    Editing Go Pro Fusion Footage in Avid 2018.3
    Hi all
    I'm wanting to bring Go Pro Fusion VR footage into my project. I've stitched it together in Go Pro VR Studio and then transcoded to a flat prores 422 file. Is that the workflow? What's the workflow if I want to buy and use the Mocha VR plug-in for Avid?
    Just want to know before I lay out the cash.
    cheers
    Scott
    Running Win10 Pro, 10 core i9, 32GB RAM, 32TB RAID, 24TB RAID, 4 x 2TB SSD, X299 Deluxe MB
    MacBook Pro i7, MacPro 2 x 2.66, 40GB Ram, GTX670 2GB, 16TB Xserve Active Raid over Dual Fibre & Fast Ethernet.32TB TB2 ARRAY,AJA LHi, BMD MINI-MONITOR... [view my complete system specs]
    www.duesouthfilms.co.nz DUE SOUTH FILMS A Film & Television Company
  • Tue, Feb 19 2019 5:54 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 491
    • Points 5,905
    Re: Editing Go Pro Fusion Footage in Avid 2018.3
    Boris CC has VR AVX effects (though I've not used them). You can get them seperately for $199
    If you don't have this then, there should be nothing wrong with you creating an appropriate size project raster and editing your footage in Avid - however you may find reorientating tricking without the plugin.
    hope this helps
    Jake
    Media Composer 2018.9 MacPro 6 core - 32 GB RAM - OS:10.13.6 3.33Ghz iMacs, Macbook Pros. BM, AJA, Matrox After Effects, etc [view my complete system specs]
    @jaketheeditor
  • Sun, Feb 24 2019 2:29 AM In reply to
    • Due South Films
    • Posts 26
    • Points 315
    Thanks jakeheat. I was hoping someone had tried it.
    For anyone else looking :
    I have downloaded and BCC VR Untis worx fine. Still have to stitch and flatten. It will work with flattened AMA/Linked files in a standard HD project. Can't import unflattened files as per other NLE's.
    Quiet in forums this day. All on FB I guess. Such a shame. A great knowledge base here.
    thanks once again.
    SYes
  • Sun, Feb 24 2019 7:18 AM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 512
    • Points 6,565
    I myself have no need to do vr work right now. I did manage to pull up this tutorial of Mocha VR in Avid if you haven't saw it yet.
    https://youtu.be/jjEJctlvm1k
