Latest post Thu, Feb 7 2019 6:58 PM by BobRusso. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Feb 7 2019 3:10 PM
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 69
    • Points 940
    Multiple ISIS 5000 System Directors crashing w/ "Problem Saving Metadata"
    Hi all,
    We've recently been dealing with all three of our ISIS 5000 SDAs reporting "Avid ISIS System Director service terminated unexpectedly. It has done this 1 one time. The following corrective action will be taken in 20000 milliseconds: Restart the Service"
    It is then followed by a "There is a problem saving metadata" error. These tend to occur overnight between midnight and 4am, when there are no clients working.
    All three ISIS SDAs are in their own subnet with their storage engines. They are running ISIS 4.5. Clients are attached to whichever switches feed their rooms, and use the "Remote Host" option in the ISIS Client. Client use ISIS Client 4.7.11 to connect.
    The only recent change, and it seems likely this may be the cause, is that a NEXIS SDA/E4 have been brought over from a secondary location and added onto the Avid network. It too is in it's own subnet, and is running NEXIS 2018.11. The clients who access the NEXIS are also running NEXIS Client 2018.11.
    Just like the ISIS Clients, the NEXIS clients may be interacting with the switches in the sub domains of the ISIS', and they are utilizing the "Remote Host" option to access the NEXIS. Sometimes the NEXIS clients can see one of the ISIS units, but obviously cannot connect due to the version incompatibliity of ISIS 4.5 and the NEXIS Clients.
    Is it possible that because the ISIS are not running 4.7.11 that the presence of the NEXIS or NEXIS clients is causing some sort of hiccup in the ISIS System Directors?
    Thanks!
    Filed under: ,
  • Thu, Feb 7 2019 3:18 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Multiple ISIS 5000 System Directors crashing w/ "Problem Saving Metadata"
    There's no telling what the issue could be; ISIS 4.5 is an extremely old version with a host of known issues. I strongly recommend upgrading to 4.7.11 and updating the clients to the latest NEXIS Client. It's amazing you've been able to run v4.5 for so long.
  • Thu, Feb 7 2019 3:44 PM In reply to
    edit: nevermind (I didn't understand clearly)
  • Thu, Feb 7 2019 5:12 PM In reply to
    • dklein
    • Posts 69
    • Points 940
    Thanks Bob,
    The ISIS environment is  inherited from a corporate acquisition, and getting it updated is high on my list. The Nexis is coming from the environment I’ve been maintaining (which had its own ISIS 5000 on 4.7.11 without issue), so there’s that.
  • Thu, Feb 7 2019 6:44 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
    ISIS v4.5 was released in 2013. Is this a 5000 or 5500? The 5000 was EOL last year. The 5500 goes EOL next year. Either way, theses disks have been spinning for a very long time and it is likely time to start migrating away from them, I'm unsure if you can even order parts for the 5000/5500.
    While you're doing the ISIS upgrade, I'd recommend upgrading the MegaRaid software also.
    As the drives start reporting high error counts, unless you're prepared to lose all the media (and with drives over 5 years old - you should be prepared for this), I recommend not doing a preemptive drive replacement. I've seen a second drive fail in a LUN while the first was being repaired a number of times.
  • Thu, Feb 7 2019 6:50 PM In reply to
    • dklein
    • Posts 69
    • Points 940
    They are ISIS 5000 units. The MSP that's been servicing them has been replacing drives as they start to show error counts, but yes, I agree with your recommendation.
    My goal is to push towards replacing these as possible with NEXIS units as soon as possible, but we will have to see how that goes.
    Is the MegaRaid software included in the ISIS Software update download, or should I look elsewhere for that?
  • Thu, Feb 7 2019 6:58 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,255
    • Points 27,835
    The MegaRAID software is available from Broadcom. Avid stopped shipping updated versions a long time ago because it included Oracle's Java; you can get the installer from Broadcom and run it. The UI is much more responsive along with bug fixes.
    Preemptive drive swaps makes me very nervous.
