Latest post Sat, Feb 9 2019 3:59 PM by BenoitM. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Feb 7 2019 1:40 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,199
    • Points 14,390
    wanted: simple EDL workflow/tutorial
    I tried a lot of things but still can't find my way out of a situation where an updated group causes a sequence to be essentially no longer editable (http://community.avid.com/forums/p/196284/878538.aspx#878538)
    to avoid starting from a fresh sequence (hours of work lost), exporting the offending sequence as EDL then importing in a new sequence is perhaps the best thing to do, but I've never used EDL.
    • Will EDL help me in recreating a new sequence from a fresh, updated group clip, and keep the edits done so far ?
    • For this simple MC->MC roundtrip, what EDL format (& options) should I use ?
    • Is there any tutorial for this simple workflow ?
    MC 2018.12.1 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.0.0.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
  • Sat, Feb 9 2019 3:59 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,199
    • Points 14,390
    Re: wanted: simple EDL workflow/tutorial
    I tried creating a EDL with all defaults in the List tool (a.o. File_129 as format); I loaded the sequence I need, and selected the V and A ttracks of interest.; when I clicked Preview, I got a handful of "Assertion failed", but pressing 'Continue' each time, I managed to finish the process with a few warnings; I then saved the list.
    I then did 'Import EDL' and got a sequence looking like like the one I need, except that all media is offline (T/L red from start to finish); I Decomposed the new sequence, no change. I could not relink to anything.
    Obviously, either I need to change some options (help !!!), or the EDL route is NOT my saviour for my group clip problem.
    Any other suggestion ?
