Latest post Thu, Feb 7 2019 2:02 PM by Pat Horridge. 4 replies.
  • Wed, Feb 6 2019 9:49 PM
    Transcoding issues
    I'm backtracking on a lot of past projects and came across a final edit comprising lots of video and audio tracks, with a mixed bag of imported and AMA-linked clips.  As I type this I am in the process of transcoding the sequence and ticked the box where it asks whether to transcode only linked media.  Assuming this is the correct thing to do, what happens now with the linked media in the edit - is it now replaced with the transcoded MXF files? If not, how to duplicate (not sure of the correct terminology) the existing sequence that is fully applied with all the appropriate MXF files correctly assembled?
    Anything else to bear in mind?
    DC
    Asus N55SF Notebook running Windows 10 Home Processor: Intel(R) Core (TM) i7-2670QM CPU @ 2.20GHz 2.20GHz Installed memory (RAM): 8.00 GB System type... [view my complete system specs]
  • Thu, Feb 7 2019 12:49 PM In reply to
    Re: Transcoding issues
    Anyone ??
  • Thu, Feb 7 2019 1:16 PM In reply to
    Not sure what you actually want to achieve.
    Is it a final sequence with only Avid media (no AMA linked media) and where does that Avid media need to be?
    Or do ypou just want a flatterned output of the final sequence as a master archive?
  • Thu, Feb 7 2019 1:50 PM In reply to
    Not sure how to express in the same terms you do.  I have a final sequence (completed aeons ago) that contains a mixture of MXF and AMA-linked files.  I would like the whole thing as MXF - for ease of use, QT Ref files, putting straight into Sorenson Squeeze, etc..  last night I performed a transcode and ticked for only linked files, assuming this only transcodes that which had not been previously performed.  Now, is there some way of instructing the final sequence tro replace that which it contains as AMA-linked files with the newly-transcoded equivalents so as to have a complete sequence comprising MXF files?
  • Thu, Feb 7 2019 2:02 PM In reply to
    When you open the Transcode window there is an option you can tick to create a new sequence. this will make a sequence copy linked to the newly created media. That should do what you need.
