Latest post Thu, Feb 7 2019 2:14 PM by BobRusso. 3 replies.
  • Tue, Feb 5 2019 9:38 PM
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 353
    • Points 4,165
    promise sanlink ethernet adapters?
    Has anyone deployed promise sanlink etherent adapters for MacOS Nexis clients? I undertstand they aren't on the HCL, but from my investigations so far, it appears they just weren't tested.
    I am looking at TB2 and TB 10G Base-T/N and 10Gb SFP+
    yes, i understand that the qualified adapters are Atto, but they are 10-50% more expensive and not available in the same quantities. Additionally, we use sanlink adapters for fibre channel clients elsewhere.
    Dave
    "A very big network"
  • Tue, Feb 5 2019 9:50 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,251
    • Points 27,805
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: promise sanlink ethernet adapters?
    If you're looking for something less expensive, the Sonnet 10G Solo 10GBaseT 1 x 10 Gb NIC is also supported with NEXIS, page 17 of the Network and Switch Guide. It uses the same Aquantia NIC as the iMac Pro that doesn't work with ISIS.
  • Wed, Feb 6 2019 10:00 PM In reply to
    • NYnutz
    • New York City
    • Posts 353
    • Points 4,165
    thanks Bob, i missed that one.
    have you seen anyone use either of the Qnap products on this page:https://www.qnap.com/en-us/product/qna-tb-10gbe
    they are also using quantia chipsets.
    Dave
  • Thu, Feb 7 2019 2:14 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,251
    • Points 27,805
    I don't know of anyone using it personally. There's a good chance it would work as it is using the same chipset but it appears to cost the same amount as the Sonnet. I'm not sure what advantage there would be to use an unproven NIC.
