Latest post Tue, Feb 12 2019 2:58 PM by Isaac T.. 17 replies.
Page 2 of 2 (18 items) < Previous 1 2
  • Tue, Feb 5 2019 3:10 PM In reply to
    Re: Managing media
    It is possible in windows to map a drive letter to a network location. That network location could be a subfolder for media for that project. Before you launch MC you run the command to mount the required netowrk location as a drive.
    Then in MC you just use that drive letter (you need to enable all drives int he console)
  • Tue, Feb 12 2019 12:56 PM In reply to
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 176
    • Points 2,465
    Re: Managing media
    One nice feature with Avid is that when it creates an MXF file, it takes as the first 6 characters of the resulting filename the same first 6 characters of the clip name. Followed by a hyphen.
    This is useful. In our company we give each source videotape both an archive number and a reel number (the reel number being particular to the particular production. And we use the archive number - which is unique to the reel - as the first six letters of the clip name when logging/capturing. So a typical clip would be called for example 500126-Clip-001 - when this gets captured, the resulting MXF files all have the prefix 500126-followed by the mxf identifier string.
    This makes weeding the storage for files  and sorting them into project-specific sub-folders really easy, as we can see from the start of the MXF filename what source reel the file relates to.
    Similarly, imported media - such as DSLR footage, voiceovers, graphics, are usually created outside Avid with filenames that begin with the production number - which conveniently is also a 6-digit number, so this also survives as the start of the resulting MXF filename - once again making sorting easy.
    So on only needs to ensure that clip names and imported file names begin with a useful, project or reel-specific 6 digit number and the MXF files Avid generates will always be identificable as to which project or reel they relate to.
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-2640 6-core HT 2.5GHz CPU 32GB RAM NVidia Quadro K4000 Graphics on Win7x64... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
  • Tue, Feb 12 2019 2:58 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 747
    • Points 8,810
    Re: Managing media
    @Adrian Redmond: I'm sure I'm kickin' the hornets' nest here, but you would love MDV. Shows you all the meaningful, human-readable metadata attached to that MXF.
    Yep, sometimes it doesn't read metadata. But if you're not roundtripping to Resolve, and you're transcoding all your source footage in Media Composer before the edit, it should all be there.
    And yes, the Windows version is old, but it's fully functional.
    Cannot recommend enough.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
