Latest post Fri, Feb 1 2019 9:16 PM by Adam 1980. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Feb 1 2019 6:43 PM
    • Adam 1980
    • Joined on Tue, Dec 6 2011
    • Posts 10
    • Points 140
    Avid Nexis Pro not Indexing Media
    SO I just set up and an AVID NEXI PRO 40tb on two macs and for some reasoning its not looking for new media if I dop a folder in the MXF folder.
    So I did create a title in avid and set AVID to make the MXF files and it created in a folder under Avid MediaFiles/MXF/"computer name" and when I drop mxf files into that folder it will recongize and update it. But lets say I drag a folder labeled "1" or "101" with mxf files it won't search of those like it would on just a normal external hard drive.
    Do I have something not selected? Is there something I need to set up with the work space?
    Thanks in advance for your help.
    Adam
  • Fri, Feb 1 2019 8:21 PM In reply to
    Re: Avid Nexis Pro not Indexing Media
    Indexing of media is not done by the server (unless you are using Interplay / MediaCentral). It is always done by the editing computer that "owns" that folder. Thus, Machine A will always index MXF folders named "Machine A.x" where x is a number.
    So rename your "1" or "101" folder by prefacing it with a machine name (i.e. Machine A.101).
  • Fri, Feb 1 2019 8:44 PM In reply to
    • Adam 1980
    • Posts 10
    • Points 140
    Ok so lets say I have another computer hooked up that drive and I create media on that computer and it puts it Machine B. 101 folder, will my other machine regnozie it?
  • Fri, Feb 1 2019 8:56 PM In reply to
    Yes
  • Fri, Feb 1 2019 8:58 PM In reply to
    • Adam 1980
    • Posts 10
    • Points 140
    So that is not happening... I am not sure why....
  • Fri, Feb 1 2019 9:04 PM In reply to
    If you import media using Machine B, it should create a folder.
    Did you save the bin and close then re-opened it in the other system?
    Can you take a screenshot of your media folder structure?
  • Fri, Feb 1 2019 9:16 PM In reply to
    • Adam 1980
    • Posts 10
    • Points 140
    So it creates the folder but Machina A does not update or recongize Machine B folder, I try to drag Machine B's database file into an Avid project and it won't load on Machine A
