Latest post Thu, Jan 31 2019 3:06 PM by Julian. 4 replies.
  • Wed, Jan 30 2019 9:23 AM
    • Julian
    • Joined on Thu, Jun 14 2018
    • South Africa
    • Posts 28
    • Points 290
    Source Colour space for 10 bit stills
    Hi
    I am getting a colour shift when importing 16bit uncompressed .tiff files saved with either ProPhoto or Adobe RGB (1998) colour profiles and can't find a source colourspace in "Source Settings"
    The images are being exported from Capture One Pro.
    What is the best way to deal with it whithout going 8bit sRGB?
    Avid MC 2018; AMD Treadripper 1950x; Asus Zenith Extreem; msi gtx970; 32gig Gskill trident 3200mhz; EVO 960 250 sys drive; ibm 5014 raid0 with 3x3tb WD... [view my complete system specs]
  • Wed, Jan 30 2019 11:52 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 917
    • Points 11,740
    Re: Source Colour space for 10 bit stills
    Try the source color space setting: "Rec. 709 [video levels]". This will import colors without modification to video levels.
    Joachim
    Joachim Claus
  • Wed, Jan 30 2019 12:48 PM In reply to
    • Julian
    • South Africa
    • Posts 28
    • Points 290
    Joachim Claus:
    Joachim
    Hi Joachim
    This is the exact issue; Avid MC is not reading the colour space of the file as there is no source colour profile for the standard images except sRGB which is ideal for 8bit images but not 10bit.
    Is there a way of installing a Adobe RGB (1998) as a “Source colour space”  in Source Settings?
  • Thu, Jan 31 2019 1:58 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Rather than use Rec. 709, you might want to consider using Rec. 2020. It encompasses then entire range of Adobe rgb (1998) and almost all of ProPhoto. This assumes you're in a Progressive project (Rec. 2020 is not supported for interlaced).
    Dave S.
  • Thu, Jan 31 2019 3:06 PM In reply to
    • Julian
    • South Africa
    • Posts 28
    • Points 290
    Hi DStone
    I don’t think rec 2020 will work for now as yet there is still no way I can convert stills to rec 2020 or rec 709.  I will just convert stills to sRGB.  Its not too serious as the output is still 8bit 422.  My projects and all the footage I receive from our camera’s is 10bit rec 709 though.
    I thought I was just missing something.
