Latest post Tue, Nov 12 2019 4:07 PM by yoruba. 2 replies.
  • Mon, Jan 21 2019 8:23 PM
    Get list of folders and directories from IPWS
    I'm trying get the folder hierarchy in Interplay via web services, but at the moment it seems the only way to get it is to run GetChildren() and recursively run GetChildren() on every folder returned until I get the whole hierarchy.
    Is there a better method anyone knows of?
  • Tue, Nov 12 2019 2:19 PM In reply to
    Re: Get list of folders and directories from IPWS
    Hello Ryan,
    Recommended to use CTMS API wherever it's possible. You can replace the IPWS calls with new Platform API.
    This requires platform authentication though. For example a valid application ID to connect to the platform, etc.
    You can find more detailed information on the links below: CT-MS APIs - Resources. Resource - loc:locations. There are also CTMS Examples on GitHub for Java, .NET (C#) & Node JS: Examples. TY/Vlad.
  • Tue, Nov 12 2019 4:07 PM In reply to
    • yoruba
    • Joined on Wed, Jun 15 2016
    • Posts 8
    • Points 110
    Hello Ryan, what you can try is to search on Type is Folder on the root.
    Then you get all the folders with the path.
    With this list you can extract the hierarchy in you app.
