Latest post Fri, Mar 1 2019 6:41 PM by NYnutz. 3 replies.
  • Mon, Jan 14 2019 11:42 PM
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 63
    • Points 880
    DeviceDisappeared event detected on md device /dev/md14
    Hi all,
    This our editors started complaining of speed issues and MC 2018.5 started reporting some Exceptions. As this was happening across projects and workspaces, we went to check out our NEXIS log and noticed that around the time editors are gertting errors we're seeing the following error:
    It's also followed by a detected capactiy changer info line: md14: detected capacity change from 26197557248 to 0
    Some time later there will be a warning that a NewArray event is detected for md14:
      mdadm TGroupSDA-top NewArray event detected on md device /dev/md14
    The NEXIS and all clients are 18.9.1.16. Any help woul dbe appreciated.
  • Wed, Jan 16 2019 11:40 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 349
    • Points 4,095
    Re: DeviceDisappeared event detected on md device /dev/md14
    if this was a single SDA SSD, i would expect to see the device listed as /dev/sdX/serialnumber, however, /md is multiple device, as in a raid group. I wonder if both of the SDA metadata SSDs are going offline simultaneously - controller or chassis failure. You should get in contact with avid support URGENTLY.
    Dave
    "A very big network"
  • Fri, Mar 1 2019 2:29 PM In reply to
    • NYnutz
    • New York City
    • Posts 349
    • Points 4,095
    interestingly, i had this same issue today on an a stack of E4s with and SDA. it looks like it happened around the same time that a workspace filled to 100% and caused media indexers to freak out and lose connectivity to nexis. ill let you know when i get something back from support.
    Dave
  • Fri, Mar 1 2019 6:41 PM In reply to
    • NYnutz
    • New York City
    • Posts 349
    • Points 4,095
    From support:
    DeviceDisappeared event detected on md device /dev/md14 in NEXIS is the System Director metadata backup partition.
    I assume this means it gets mounted at a regular interval for metadata backup and unmounted once complete.
    This is a silly thing to flag with error and not information.
    Dave
