Latest post Fri, Jan 11 2019 12:04 AM by Twosheds. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 10 2019 5:34 AM
    • Twosheds
    • Joined on Wed, Mar 15 2006
    • Melbourne, Australia
    • Posts 85
    • Points 925
    MC 2018.12 ProRes export problems
    I have just done a clean install of MacOSX 10.14.2 Mojave onto a 2015 27" iMac. I installed Avid Media Composer 2018.12 and during testing found I was unable to export an Apple ProRes Quicktime.
    Previously we did have Apple Compressor, DVD Studio Pro installed which meant the Apple Pro quicktime components were installed.
    Do I need to install the old software or should I be able to export a ProRes Quicktime directly from MC2018.12
    thanks
    Media Composer with Symphony option v8.10.0, MacOSX 10.11.6, Avid DNxIO [view my complete system specs]
    Filed under: , ,
  • Thu, Jan 10 2019 9:33 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 59
    • Points 800
    Re: MC 2018.12 ProRes export problems
    If you don't mind to install Compressor then that will bring back the codec(s). I think DVD Studio does too, but I haven't installed that software in a long time. When you own at least one of the pro apps - as you do - there are other ways to install the codecs only, without installing one of the apps. (For example google "install prores without proapps")
    There might be better answers though. I always install Compressor on any new setup, not (only) for the codecs but rather for its actual purpose. So I never went into that question any further.
  • Thu, Jan 10 2019 1:42 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    Hi Twosheds,
    No, you do not have to install the old software.
    Yes, there is a way to do this without installing the old NLE's. Take a look at the link below!
    Installing the Apple Pro Video formats without Final Cut Pro or ProApps
    Enjoy!
    Friendly greetings,
    Ivan
    Avid Media Composer 2018.10.0.49715.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
    Yes, I have installed the latest DX driver.
  • Thu, Jan 10 2019 3:05 PM In reply to
    FYI - I think this technically violates Apple EULA. You need a licensed ProApp in your computer to officially activate ProRes encode.
    A better non-EULA-violating workflow is to do a mixdown in Avid and export as Same As Source.
  • Thu, Jan 10 2019 5:11 PM In reply to
    Without the ProRes codec installed, it will not be an option as a Custom QuickTime export. But as Dom says, you can do the mixdown and export Same as Source.
    You should be able to open ProRes movies in QuickTime X.
  • Thu, Jan 10 2019 7:06 PM In reply to
    • janusz
    • Paris
    • Posts 394
    • Points 4,535
    Another factor (undocumented as far as I am aware, but confirmed by tests I performed a few years ago) is that the use of a Custom... QT export (i.e. by configuring the Quicktime-provided dialog box that appears) is *always* an 8-bit export regardless of the source codec or the chosen destination codec.  I doubt this has changed since I performed these tests.
    As a result, with sequences relinked to 10 bit AMA sources, or sequences containing 175X/185X/220X media, a mixdown to Prores followed by a same-as-source export gives a higher quality result (the native Avid codecs are used, and Quicktime is not involved).  Furthermore, the colorimetry can be more accurate - the levels options do not influence a SAS Prores export (they modify metadata on DNx exports that affect the decode levels with the quicktime codec).  I always recommend this workflow, and avoid Custom...  in nearly all cases.
    Janusz
    MC 2018.12 / OS 10.12.6 + others elsewhere [view my complete system specs]
  • Fri, Jan 11 2019 12:04 AM In reply to
    • Twosheds
    • Posts 85
    • Points 925
    Yeah, I thought so. I think I'll just install Apple Compressor and then delete the actual Compressor app. We have Adobe Encoder as well.
