Latest post Thu, Feb 14 2019 6:48 PM by Bruce Dixon. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 10 2019 2:40 AM
    • kokopelli
    • Joined on Tue, Mar 2 2010
    • Posts 65
    • Points 785
    AMALogger
    Does anyone know why I have recently been getting AMALogger files? I've never gotten them before and now I have almost 100.  Can I delete them?  I guess I started getting them on 10/2/18. It seems I'm getting one every day I use MPC.
    Thanks.
  • Thu, Jan 10 2019 3:57 PM In reply to
    • cmush
    • Joined on Fri, May 25 2012
    • Posts 44
    • Points 540
    Re: AMALogger
    I'd love to know how we can disable the logging.  Ever since I've updated to 2018.11 I get them.  It is cluttering up the root of the drive.
  • Thu, Jan 10 2019 4:10 PM In reply to
    Re: AMALogger
    Let me check and get back to you guys...
  • Sat, Feb 2 2019 10:36 AM In reply to
    Re: AMALogger
    Hi Kevin
    Do we have an answer on this at all - I also have a user folder on Mac filling up with these AMA Logger files and would like to know the implcations of deleting them - any thoughts on this would be good - it seems there's quite a lot of people that may like to know the answer to this conundrum...
    Many thanks
    Tim B
  • Sat, Feb 2 2019 10:40 AM In reply to
    Re: AMALogger
    Hi Kevin,
    Also having the same issue with these files - can they be deleted or will it cause issues with my existing setup?
    Cheers
    Huw
  • Mon, Feb 4 2019 4:01 PM In reply to
    Re: AMALogger
    I hadn't heard back, so I pinged them again...stand by...I'll report as soon as I know.
  • Thu, Feb 14 2019 6:48 PM In reply to
    • Bruce Dixon
    • Washington, DC
    • Posts 42
    • Points 550
    Re: AMALogger
    I'm seeing them on Mac OS 10.13.6 in the user home folder. ( /Users/AvidEditor/ ) There seems to one file created for each day that Media Composer is used. On a Mac running Mac OS 10.12.6 the files are at /Users/Shared/AvidMediaComposer/Avid FatalErrorReports/ and also at /Users/Shared/AvidOPFrameGeneratorApp/Avid FatalErrorReports/. We noticed this change in the Fall of 2018.
    As a workaround I just created a folder called Avid Logs in my home folder. Whenever I notice more files have appeared, I just drag them to Avid Logs and keep working. I would suggest not moving them while Media Composer is running. Otherwise I think it's safe to do whatever you want them. Log files are generally just for diagnostic purposes. I think MC only cares about the most recent file. The older ones are probably only needed if you're troubleshooting an issue.
    Ultimately Avid should fix this so log files are saved in their own folder, away from other user files.
    We have 6 Media Composer systems. All are running MC 2018.12 and Mac OS X 10.13.x 2 of the MC systems have Mojo DX hardware and the Symphony option ... [view my complete system specs]
    Bruce Dixon
    EFX Media
    Arlington VA 22204
    USA
