Latest post Sun, Dec 30 2018 7:08 PM by funckdren. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Dec 22 2018 6:35 PM
    • Ivo
    • Joined on Fri, Oct 21 2005
    • Germany
    • Posts 521
    • Points 7,005
    Modify keyboard with command+ ?
    I want to modify the keyboard "command + arrow left". Is this possinble?
    Avid Media Composer 2018.9 MacBook Pro [view my complete system specs]
  • Tue, Dec 25 2018 2:31 PM In reply to
    Re: Modify keyboard with command+ ?
    Hi, nope, you can only customize shortcuts with "shift + (arrows) "
    Regards.
       Diego
    * Avid Media Composer 2018.2 * Interplay | Production 3.8.1 * Media Central 2.10
  • Fri, Dec 28 2018 4:17 PM In reply to
    • funckdren
    • Boston, MA
    • Posts 444
    • Points 5,955
    It's possible, but only with a third-party app like Quickeys or Karabiner.
    Karabiner is much more powerful, but a little less user friendly. Either one should work for what you're hoping to do.
    Mac Pro Westmere 12-Core 3.46GHz, Media Composer 8.6.4, Mac OS 10.11.5, 64GB RAM, Mojo DX [view my complete system specs]
  • Fri, Dec 28 2018 5:09 PM In reply to
    • Ivo
    • Germany
    • Posts 521
    • Points 7,005
    Yes you are rigth I don't understand how to use Karabiner. I even don't understand how to ask the rigth question in the forum.
  • Fri, Dec 28 2018 8:05 PM In reply to
    • funckdren
    • Boston, MA
    • Posts 444
    • Points 5,955
    If I were you I'd start with Quickeys first. I think support for it is starting to drop off, but I believe it works up through OS 10.12, and you can download a fully functioning trial to make sure you like before you buy.
    First, in MC assign the function you want to an unused key (F1 for example). Then you create a hot key in Quickeys -- basically tell it to press F1 every time you press "command + arrow left." You can also set it so this happens in Media Composer only.
    If for some reason Quickeys does not work for you, Karabiner is awesome and worth the trouble for customizing your keyboard beyond what MC allows.
  • Sat, Dec 29 2018 6:08 AM In reply to
    • Ivo
    • Germany
    • Posts 521
    • Points 7,005
    Do you know how to set "command + arrow left" to F1 in Karabiner?
  • Sun, Dec 30 2018 7:08 PM In reply to
    • funckdren
    • Boston, MA
    • Posts 444
    • Points 5,955
    Look at this page and scroll down to Configuration. Your two-key combo may be a "Simple Modification." If the addition of the modifier key makes it a "Complex Modification" you'll need to create a new rule...probably best to appeal to someone for help in the Karabiner community for that. I used to be able to build custom rules but Karabiner has changed over the years and now uses .json files which I haven't had time to explore. I recently needed a custom rule built and asked for help in a Karabiner forum and someone helped out.
    Explore the Simple Modification solution first and report back.
    Again, Quickeys is easier for what you wanna do.
