Latest post Tue, Dec 18 2018 12:39 PM by JamesTV. 0 replies.
Page 1 of 1 (1 items)
  • Tue, Dec 18 2018 12:39 PM
    • JamesTV
    • Joined on Fri, Mar 31 2017
    • Posts 26
    • Points 320
    AAF Generation using AMT v3
    We are assessing the use of AMT v3 in our implementation - and are very keen to try and make use of the AAF generation capability that it includes. However, the example only supports a single file per AAF - which is a bit pointless as the whole idea for AAF is to connect multiple files and present them as a sequence.
    Is there any way to provide mutilple source OPAtoms into this AAF generator?
     AAFCreationOptions ()
                this -> addArgument (Common::makeArgument ("Source MAD", "Source media asset description xml path", m_sourceMADPath, ArgumentRequired));
                this -> addArgument (Common::makeArgument ("Output AAF", "Output file where to write the resulting AAF.", m_outputFile, ArgumentRequired));
     // Add optional parameters
                MediaParameters mediaParameters;
                JobSetupUtils::setMediaParameters (mediaParameters,
                                                   m_options.m_masterMobID,
                                                   m_options.m_physicalSourceMobID,
                                                   m_options.m_tapeName,
                                                   m_options.m_psmDescriptorType,
                                                   m_options.m_psmTimecode,
                                                   0);
