Latest post Tue, Feb 12 2019 7:53 PM by Alexandra Nichelle. 7 replies.
  • Sun, Nov 25 2018 12:01 AM
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 141
    • Points 1,900
    Can't export of mixdown: errcode:-2034.
    I’m getting an error everytime I’m trying my 4k projectr: errcode:-2034.
    I’ve tried exporting in both 4K and HD with DNxHD or DNxHR. I’ve tried, ProRes, H264, same error all the time after just a few seconds.
    I’ve tried the divide and conquer method but it won't export no matter how small my selection is.
    I’ve tried creating a new sequence with just a few seconds on my original sequence and I get the same error.
    I’ve tried trashing my settings.
    Exporting the Audio only works fine.
    I’ve tried to export to multiple drives (with plenty of space. Mac HD also have space), with multiple (very basic) file names.
    95% of my clips are transcoded to DNxHR LB. A few are linked. I’ve tried with a sequence with just 3 DNxHR LB clips, and I’m having the same problem.
    This is the error I get from the console:
    18.10.0.49715.0
    • Exception: Movie export from procedures FAILED!, errcode:-2034
    Duplicate definition entry (not added)
    Plugin definition registration failed
    Audio Mixdown will require 9621624 bytes. AudioSamplesInSequence= 1603604, SequenceLength= 801, DestinationBytesPerSample= 3, numOutputChannels= 2. 9396 KB needed.
    Exception caught in APlayer::Play - Exception: CACPLGPUOutputConverter::ExecuteRequest() - GPU to Host transfer failed!, hr:0x80000002
    Internal Exception hit: CACPLGPUOutputConverter::ExecuteRequest() - GPU to Host transfer failed!.
    CQTExportManager::QTWMovieExportFromProceduresToDataRef: MovieExportFromProceduresToDataRef failed, File: /Snapshots/relengmaverick1_1537900880/xplat/OOP_Wrappers/QuickTime/QuickTime_Core/projects/mac/../../source/QTExportManager.cpp, Line: 2677
    Exception:
    @ Sat Nov 24 18:46:22 2018
    I’ve tried a Video Mixdown and this is what I get:
     18.10.0.49715.0
    DIDWriter::DoSDKHWEncodeForCapture - SDK HW encode disabled
    The only thing that seem to change something is doing a restart. When I do so, it take maybe 2 minutes before I get the same error message instead of a few seconds.
    I need help.
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Sun, Nov 25 2018 1:41 AM In reply to
    • JPBU
    • Canada
    • Posts 141
    • Points 1,900
    Re: Can't export of mixdown: errcode:-2034.
    Problem solved (for now):
    I disabled the GPU effects in the render settings...
    This make sense for the Mixdown error but I don't understand why...
  • Mon, Jan 28 2019 3:16 PM In reply to
    • VPROIMCT
    • Joined on Mon, Mar 11 2013
    • Hilversum - The Netherlands
    • Posts 9
    • Points 125
    Bumping this thread as we experience the same bahavior. Disableing gpu render does bypass this but is all but a solution. Anyone else experiencing this?
    Menno
    ps this is on PC, sorry for posting in Mac forum.
    40 x MC 2018.11 - Interplay 3.x - 256 Tb Isis 7500 [view my complete system specs]
  • Mon, Jan 28 2019 6:59 PM In reply to
    • Posts 10,079
    • Points 216,495
    what version of MC?
  • Tue, Jan 29 2019 12:03 PM In reply to
    • VPROIMCT
    • Posts 9
    • Points 125
    Hi M, got me 2018.11
    Menno
  • Tue, Jan 29 2019 2:47 PM In reply to
    • Posts 10,079
    • Points 216,495
    Try.......
    The issue seems to be when exporting with In-Out regions and when Export Selected Tracks is ticked on. Without these two settings the export goes smoothly.
    MM
  • Wed, Jan 30 2019 8:12 AM In reply to
    • VPROIMCT
    • Posts 9
    • Points 125
    Hi M no unfortunatly that did not work. Any other thoughts? :-)
    Menno
  • Tue, Feb 12 2019 7:53 PM In reply to
    Any luck with this? I've been getting the same error message.
    Avid Media Composer 8.6.0 • MAC OS High Sierra 10.13.4 • iMac (Retina 5K, 27-inch, Late 2014) • 4 GHz Intel Core i7 • 16 GB 1600 MHz DDR3 • AMD Radeon... [view my complete system specs]
