Latest post Sat, Nov 24 2018 7:20 AM by Job ter Burg. 4 replies.
  • Thu, Nov 22 2018 2:43 PM
    • J
    • Joined on Tue, Oct 19 2010
    • Posts 62
    • Points 810
    desynchronization 2 images on plasma
    Hello,
    is there a special setting on video output tool to remove a desynchro of 2 images on the plasma?
    no
    desynchro in monitor or avid screen.
    Thank you,
    J.
  • Thu, Nov 22 2018 3:35 PM In reply to
    Re: desynchronization 2 images on plasma
    What is desynchro of 2 images? are you describing interlacing artefacts?
  • Thu, Nov 22 2018 5:08 PM In reply to
    You'll have to put a delay in your audio monitoring chain. Or route your audio monitoring signal through the monitor, if the monitor has built-in delay compensation.
    You can set the delay for the source/record monitors in the Console, using MonConDelayms.
  • Fri, Nov 23 2018 9:30 AM In reply to
    • J
    • Posts 62
    • Points 810
    Thank you for your answers.
    if i understand i need to put a delay on my plasma, not in Media Composer ?
    I dont' know MonConDelayms ? I do not know My ConDelayms. is this software?
    I think I found something, I tried to get the sound of the plasma by the headphone jack, and bring it on the mixer but it does not work for the moment. How can I bring the plasma sound to my mixer and then send the sound back to the computer?
    Confused
  • Sat, Nov 24 2018 7:20 AM In reply to
    The plasma monitor is causing the delay (all modern monitors do). You’ll have to delay the sound by the same amount.
    if you do, tue Source & Record Monitors in Media Composer will then be early. You can delay those as well by opening the Console (ctrl-6/cmd-6) and type “MonConDelayMS xxx” where xxx is the amount of milliseconds that your plasma screen and audio path is delayed.
    I don’t know what you mean by getting the sound back to your computer. You need the sound to get to your speakers.
