Latest post Fri, Nov 23 2018 7:46 PM by BobRusso. 7 replies.
  • Wed, Nov 14 2018 9:35 PM
    • dklein
    • Joined on Thu, Mar 15 2012
    • Posts 56
    • Points 815
    Mount NEXIS Workspace from Mac Command line
    Hi all,
    Is there a way to mount NEXIS workspaces from the command line on a Mac? We're looking to automate our project backups to local drives, and we're hoping to be able to mount workspaces and unmount workspaces via scripts, rather then requiring the workspaces to be premounted.
    Thanks!
    Filed under: , ,
  • Thu, Nov 15 2018 7:22 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Re: Mount NEXIS Workspace from Mac Command line
    You will still need to have the client installed but this example should work:
    mount.avidfos JohnnyAppleseed:password123@NEXIS-A/workspace /mnt/workspace -o umask=777
  • Thu, Nov 15 2018 7:47 PM In reply to
    • dklein
    • Posts 56
    • Points 815
    Hi Bob,
    Thanks for the reply. The NEXIS client is currently installed, but running that command with one of our users/workspace filled in, Terminal throws the error:
    mount.avidfos is not found.
  • Thu, Nov 15 2018 10:58 PM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 262
    • Points 3,480
    maybe you need "mount_avid" command?
    Usage: mount_avid [options] <servername>:<workspacename> <mount point>
        Mounts an avidfs filesystem
    General options:
        -o options  : standard mount options
        -m mode     : maximum access modes (octal) allowed to filesystem
    Root user options:
        -U name     : avidfs server user name to use [required]
        -u user     : Unix user (uid or name) granted owner access to filesystem
        -g group    : Unix group (gid or name) granted group access to filesystem
    my zoo: NEXIS Pro 40 tb sw v18.6.1; MBPro_late_2013 15'' i7 16GBram OSX 10.12.6 MC 2018.12 BMD US monitor (or AJA io XT ), EXT thunderbolt NvidiaGPU... [view my complete system specs]
    DJFio[DB]
  • Thu, Nov 15 2018 11:13 PM In reply to
    • dklein
    • Posts 56
    • Points 815
    That's it! Thanks!
    The below will mount a NEXIS parititon via command line on a mac:
    mount_avid -U user:password server:workspace /Volumes/workspace
    This will then unmount the workspace using the command line:
    diskutil unmount /Volumes/workspace
    Thanks for your help DJFio[DB]!
  • Thu, Nov 15 2018 11:43 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    Sorry, I gave you the Linux command.
    Use the following command to mount a NEXIS workspace on a Mac:
        mount_avid -U <username>:<password> <virtual server name>:<workspace name> /Volumes/<mount point>
    Example:
        mount_avid -U administrator:secret AvidNEXIS:bot /Volumes/bot
  • Fri, Nov 23 2018 4:01 PM In reply to
    Is there anything similar for Windows so one can use CMD or Power Shell?
    Beent
    HP Elitebook 8540W, win7 8GB Ram [view my complete system specs]
  • Fri, Nov 23 2018 7:46 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
    On Windows the Client Manager is just a simple UI that was made to allow users to easily mount workspaces. Workspaces can be mounted the same way any file system is mounted.
    For example, from the Command Prompt:
    net use z: \\NEXIS_name\workspace_name password /USER:username
    Or programmatically using the same underlying Windows calls that "net use" uses:
    WNetUseConnection();
    The only thing to be aware of is that the NEXIS drivers need to load prior to the script.
