Latest post Mon, Mar 25 2019 12:33 PM by Marianna. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Nov 9 2018 2:56 PM
    • jcmcnamee
    • Brooklyn, NY
    • Posts 230
    • Points 2,450
    Phonetic Indexer hanging
    I've had a problem on 2018.10 where I can't eject a media drive (once avid has quit) because macOS says an application is still using it. It seems that the process that is still using the drive is Avid Phonetic Indexer and it's usually red in the Activity Monitor. I can quit the process there and the drive ejects. But something is causing the phonetic indexer to get stuck. Is it suppsed to stop running when I quit avid? Could there be something that got corrupted in the phonetic index on that drive that is causing the problem? Looking for troubleshooting advice. For the record I have only used this particular drive with 2018.10 and no previous versions so this isn't necessarily a 2018.10 issue. I was running 2018.5 before this.
    Media Composer 2018.12.3 / OS 10.14.3 27" iMac [3.5 GHz Intel Core i7, 32 GB ram, NVIDIA GeForce GTX 780M 4GB] [view my complete system specs]
  • Fri, Jan 11 2019 1:51 AM In reply to
    • highfly900
    • Bozeman, MT
    • Posts 71
    • Points 945
    Re: Phonetic Indexer hanging
    Bumping this since I am seeing the same think and havent found a way to disable it. All it does is get stuck and take up RAM
    2.66 Ghz i7 Macbook Pro OS X 10.6.6 4GB RAM MC 5.0 [view my complete system specs]
    -danimal the animal
  • Thu, Jan 24 2019 4:23 AM In reply to
    Ditto for me.   After closing AVID this process still shows as active and is taking up a ton of RAM.    2018.11.0 Mac / High Sierra.   Only way to get it to stop is to restart :(  Guess i will have to carve out some time to setup a support ticket..
    MacPro AVID MC 6.5.2 / Mac OS 10.7.5 / 2x 3GHz Quad-Core Intel Xeon / 20GB RAM / Dual Monitor 1-30" 1-24" / One big ass hamster on a tread mill... [view my complete system specs]
  • Thu, Mar 14 2019 3:40 PM In reply to
    OK - Plus one from me. I'm seeing the same thing in the Activity Manager as in the screenshot - sometimes Phoneticindexer quits, sometimes not. MC 2018.10 on Sierra 10.12.6. Getiing very annoying!
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Thu, Mar 14 2019 4:24 PM In reply to
    Stupid question - is this process linked to the Phrasefind feature? I have it on trial. If not activated, will the Phoneticindexer thing cease to trouble me? Can it be deactivated if present>
  • Thu, Mar 14 2019 4:57 PM In reply to
    • Posts 10,204
    • Points 218,070
    highfly900:
    Highfly..... what exact MC version and exact OS version????
  • Thu, Mar 14 2019 5:06 PM In reply to
    • Posts 10,204
    • Points 218,070
    Jason Lyons (aka. avidzombie):
    Hey Jason.... I created a case for you.  # 03669822
    Can you update your specifications to the latest you are on please.
  • Thu, Mar 14 2019 5:10 PM In reply to
    • Posts 10,204
    • Points 218,070
    Roger Shufflebottom:
    Roger.. got a case going for you as well
    03669829
    marianna
  • Fri, Mar 15 2019 3:07 PM In reply to
    • cmush
    • Joined on Fri, May 25 2012
    • Posts 44
    • Points 540
    I just want to add that I've experienced this behavior as well.  I'm on OS X 10.13.6 and Media Composer 2018.11.
  • Fri, Mar 15 2019 3:58 PM In reply to
    • Posts 10,204
    • Points 218,070
    cmush:
    Chris - I created a case for you 03670456
  • Mon, Mar 25 2019 11:40 AM In reply to
    I'm also dealing with the same issue.
    Avid 2018.12
    Mac OS 10.14.2 Mojave
  • Mon, Mar 25 2019 12:33 PM In reply to
    • Posts 10,204
    • Points 218,070
    starkcontrast:
    Avid 2018.12
    To assist you - can you try to do the following:
    1. Close Avid Editor
    2. Go to Drive where project is located (sample path below for WIN and MAC. It will depend if your project is in local or not of course):
    Windows: C:Program Files/Avid/Avid Media Composer/Avid Projects/name of your project
    Mac: MacHD/Users/Shared/Avid Media Composer/Avid Projects/name of your project
    3.Look for the folder called "SearchData" and make a back up on your desktop then delete that folder on it's current location
    4. Re-launch Avid Editor and open project. Check your PhraseFind Indexer as well if it's able to index already.
    I'd like to know as well:
    A. The last time phonetic indexer was working for you. Last version of Media Composer and PhraseFind.
    B. A screenshot of you About this Mac
    C. Have you tried to index projects that are located on your local root folder?
    Please let me know
