Latest post Wed, Nov 7 2018 8:36 PM by Jim Blokland. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Nov 7 2018 2:13 PM
    Closed Captioning MC 2018.10 advice
    Hi there:
    Trying to get familiar with importing/exporting QT with embedded Close Captioning.  Tested import of .scc file, imported into 29.97 project.  I can lay the CC file on the Data track, but when I turn on 'Show Captions' in the Viewer window, nothing shows up.  And the .scc file seems 'empty' when viewed in the timeline, yet I know there is data there.
    Any words of advice?  Or links to detailed info re process?  Would be much appreciated.
    Best, JIM.
    MC 2018.10 Sierra 10.13.4 Westmere Octo 3.46 Mhz 48 GB RAM EVGA GTX 970 FTW GPU SATA RAID array BM DeckLink Mini Monitor 4K [view my complete system specs]
    JAMES BLOKLAND
  • Wed, Nov 7 2018 3:52 PM In reply to
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 78
    • Points 935
    Re: Closed Captioning MC 2018.10 advice
    Hi Jim,
    As far as I know Avid has never imported or exported CC's in MOV.
    I did a quick test on 2018.9 / Sierra importing an .scc in a 1080i/59 project and it did display in the Source and Record monitors. The track data is also displayed in the timeline when expanded. I did have to import using the Source Browser as the Drag and Drop import always failed with SYS_ERROR.
    Don
    1x AMC/Sy 8.2.11-Win7 Pro 64-HP z800-dual 6core-24GB-Quadro FX 4800-Nitris DX QT775 NV340.84** 3x AMC/Sy 8.2.11-Win7 Pro 64-HP xw8600-8GB-Quadro FX 3700... [view my complete system specs]
  • Wed, Nov 7 2018 5:17 PM In reply to
    Hi Don:
    Thanks for the test and info.  I'll try the same test in a 1080i/59 project, instead of the 29.97.
    I'll have to get my hands on the broadcaster delivery specs, as you suggested.  I'm also wondering, is there a better format for CC other than .scc?  I've read about a host of others.  Ideally, I'm looking for a format that would serve the most channels – ie. not just broadcast, but VOD/iTunes/Netflix, etc.
    Thanks again for your help.
    Best, JIM.
    JAMES BLOKLAND
  • Wed, Nov 7 2018 5:34 PM In reply to
    Just did the 1080i/59 test.  No different than the 29.97 project.  Still no captions displayed in the Viewers.
    Checked the settings, couldn't find anything that looked like it would help.
    Best, JIM.
    JAMES BLOKLAND
  • Wed, Nov 7 2018 6:21 PM In reply to
    • DonE
    • California, USA
    • Posts 78
    • Points 935
    Have you viewed the scc with Textedit, seeing the timecode and hex caption data?
    When you load the imported Master Clip in the Source Monitor for the first time do you get the "Converting 436M ANC Closed Caption Data..." window?
    I don't have 2018.10 on Mac OS but I do have it on Win 10. I imported scc in 1080i/59, 1080p/29.97, 720p/29.97 and 30i NTSC. They all worked. What are the full details of your 29.97 project?
    Don
  • Wed, Nov 7 2018 6:27 PM In reply to
    Hi Don:
    Yes, I see the hex data:
    Scenarist_SCC V1.0
    00:00:05:08 496e f1d3 e3f2 e962 e520 f7ef f26b 7320 ef6e 20cd 61e3 20ef f220 57e9 6e64 eff7 73ae
    00:00:07:26 c16e 6420 f768 e9ec e520 f468 e973 2064 e56d ef20 e973 20ef 6e20 f468 e520 cd61 e320 76e5 f273 e9ef 6e2c 20f4 68e5 2073 efe6 f761 f2e5 20e9 7320 70f2 e5f4 f479 206d 75e3 6820 e964 e56e f4e9 e361 ec20 ef6e 2062
    But I don't get the 'Converting 436M...' window.  When I use Source Browser to import the file, all I see is the Timecode window dialog box.
    The .scc file is just a test file I found on the net, so maybe that's the issue.  You don't happen to have a file I could test with?
    Best, JIM.
    JAMES BLOKLAND
  • Wed, Nov 7 2018 7:04 PM In reply to
    • DonE
    • California, USA
    • Posts 78
    • Points 935
    Sure. This short test should work. Rename the file .scc.
    Good luck! Don
  • Wed, Nov 7 2018 7:32 PM In reply to
    Got the file.  Thanks Don!  Much appreciated.  Will test later today.
    Best, JIM.
    JAMES BLOKLAND
  • Wed, Nov 7 2018 8:36 PM In reply to
    Hi Don:
    Yup, that file works fine.  (not sure what was up with the test files I downloaded). And the clip in the Data track showed the graphic layout, etc.
    Thanks again for all your help.  I still have to figure out best practices, and outputs, etc.  But at least I can test properly now.
    Best, JIM.
    JAMES BLOKLAND
