Latest post Mon, Nov 26 2018 11:32 PM by Charlie Gertner. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Nov 4 2018 7:52 PM
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    Playing Source Monitor creates error in Console
    Everytime after I have been playing a clip in the Source Monitor, the error below is automaticly added to the Console window.
    LegendHWbufferMgr::DumpBuffersInUse(): Dump disabled since it may take forever. Rebuild the code if needed.
    HagridBufferWrprMgr::DumpInUseBufferWrappers(): Dump disabled since it may take forever. Rebuild the code if needed.
    Any ideas where this is coming from? It looks like this happening since I installed 2018.10.
    Thanks in advanced!
    Ivan
    Avid Media Composer 2018.10.0.49715.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
    Yes, I have installed the latest DX driver.
  • Mon, Nov 5 2018 11:15 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,025
      Moderator: MCA Mac
    Re: Playing Source Monitor creates error in Console
    Got DX hardware on that system?  If so, did you install the DX driver with 2018.10?  It's no longer part of the default installation and must be installed separately.
  • Tue, Nov 6 2018 8:08 AM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    Hi hbrock,
    Yes, I have a Nitris DX on that system. The latest DX driver was installed together with the installation 2018.10.
    I could re-install it, and see what the result is.
    Thanks!
    Ivan
  • Thu, Nov 15 2018 5:14 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,025
      Moderator: MCA Mac
    Any luck with a re-install?  If not see if disabling the DX hardware makes the problem go away.  Then re-install "the version that used to work" and see if that still works with the DX hardware enabled.  Trying to help determine if the problem is software (MC version) or hardware (your DX box).
  • Fri, Nov 16 2018 4:03 PM In reply to
    And what kind of clip are you trying to play back?
  • Mon, Nov 19 2018 2:46 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    Hi hbrock,
    I didn't manage to do a re-install because of time issues. Disabling the Nitris DX hardware makes indeed the problem go away. I had no problem with any other versions out of the past. It only happens since I installed 2018.10. I can only go back to version 2018.9 because I had to buy a new annual subscription in september, making the older versions from 8.0 on dissapear. With 2018.9 I had a problem with the DMF Service, so I can't go back.
    Thanks!
  • Mon, Nov 19 2018 2:50 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    Hi Kevin,
    The footage that I am playing back is AVCHD (*.m2ts) that has been transcoded to DNxHD 120 (HD1080i). I did't have the time yet to test some other formats.
    Thanks!
  • Tue, Nov 20 2018 7:11 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,518
    • Points 64,025
      Moderator: MCA Mac
    Older versions should still work.  Your license should allow you to use any version released before the license expires.
  • Tue, Nov 20 2018 1:06 PM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 103
    • Points 1,160
    hbrock:
    Hi hbrock,
    Now I am confused. Do you mean that if someone buys a brandnew license today (2018.10), she or he also can install any older version, for example 2018.2?
  • Tue, Nov 20 2018 1:54 PM In reply to
    • Posts 10,089
    • Points 216,625
    CineMatica,
    It really depends on whether you have a dongle or SW activation.  This explains it here:
    http://avid.force.com/pkb/articles/en_US/compatibility/Using-a-Media-Composer-8-0-Symphony-Option-or-NewsCutter-Option-license-to-activate-a-previous-version
    Hope that helps
  • Mon, Nov 26 2018 11:32 PM In reply to
    As of today, we are experiencing this same error playing XDCam50 material in a simple sequence.
    One video track, comprised of XDCam50 in group clips
    Two audio tracks, from same source.
    Error is repeating every so often, though does not occur when replaying same section of sequence over again.
    Specs:
    Mac OSX El Capitan 11.6
    MacPro 5,1 cheesegrater
    MC 2018.9
    32GB RAM
    Nitris DX, with included DX drivers installed at time of MC upgrade from 8.9.2 to 2018.9
    Nablet plugins 4.5.5
    4 Systems-> MacPro 5,1 OSX 10.11.6 32GB RAM Nitris DX MC2018.9 | 2 Systems-> MacPro 6,1 OSX 10.11.6 64GB RAM Artist DnxIO MC8.x Avid Nexis 2018.5 [view my complete system specs]
