Latest post Fri, Nov 16 2018 4:03 PM by Kevin Klimek. 4 replies.
  • Sun, Nov 4 2018 7:52 PM
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 75
    • Points 800
    Playing Source Monitor creates error in Console
    Everytime after I have been playing a clip in the Source Monitor, the error below is automaticly added to the Console window.
    LegendHWbufferMgr::DumpBuffersInUse(): Dump disabled since it may take forever. Rebuild the code if needed.
    HagridBufferWrprMgr::DumpInUseBufferWrappers(): Dump disabled since it may take forever. Rebuild the code if needed.
    Any ideas where this is coming from? It looks like this happening since I installed 2018.10.
    Thanks in advanced!
    Ivan
    Avid Media Composer 2018.10.0.49715.0 | Avid Symphony Option | Avid ScriptSync 2.0 | Avid PhraseFind 2.0 | Avid Pro Tools 11.3.1.370 | Avid Application... [view my complete system specs]
    Yes, I have installed the latest DX driver.
  • Mon, Nov 5 2018 11:15 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,510
    • Points 63,895
      Moderator: MCA Mac
    Re: Playing Source Monitor creates error in Console
    Got DX hardware on that system?  If so, did you install the DX driver with 2018.10?  It's no longer part of the default installation and must be installed separately.
  • Tue, Nov 6 2018 8:08 AM In reply to
    • CinéMatica
    • Belgium | Europe
    • Posts 75
    • Points 800
    Hi hbrock,
    Yes, I have a Nitris DX on that system. The latest DX driver was installed together with the installation 2018.10.
    I could re-install it, and see what the result is.
    Thanks!
    Ivan
  • Thu, Nov 15 2018 5:14 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,510
    • Points 63,895
      Moderator: MCA Mac
    Any luck with a re-install?  If not see if disabling the DX hardware makes the problem go away.  Then re-install "the version that used to work" and see if that still works with the DX hardware enabled.  Trying to help determine if the problem is software (MC version) or hardware (your DX box).
  • Fri, Nov 16 2018 4:03 PM In reply to
    And what kind of clip are you trying to play back?
