Latest post Sat, Nov 3 2018 1:53 PM by Shar103. 4 replies.
  • Sat, Nov 3 2018 1:34 AM
    • Shar103
    • Joined on Sat, Nov 3 2018
    • Posts 3
    • Points 25
    1080 ti 8mb or P4000??? Help!
    Before I take some classes I'm doing a 6 month self study of 3d Studio Max, After Effects and Avid.  I am building a computer and need some advice.  All the programs have been tested and confirm to work with the 1080,  all except Avid which only recommends Quadro cards.  Is anyone using the 1080? Are you having problems?  Does anyone know what program features that won't work with the 1080? This what I have so far...
    Intel - Core i7-8700K 3.7GHz 6-Core Processor
    Cooler Master - Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
    Asus - Prime Z370-A ATX LGA1151 Motherboard
    Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2666 Memory
    Crucial - MX500 250GB 2.5" Solid State Drive
    Western Digital - Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive
    Cooler Master - Storm Stryker (White) ATX Full Tower Case
    Thermaltake - 750W 80+ Gold Certified Semi-Modular ATX Power Supply
    Asus - DRW-24B1ST/BLK/B/AS DVD/CD Writer
    Microsoft - Windows 10 Pro OEM 64-bit
    I don't know all I want to do with the programs because I don't know all that they can do (or what I can imagine).  I'm starting out wanting to edit videos, doing some animation and adding special effects.
  • Sat, Nov 3 2018 8:10 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Re: 1080 ti 8mb or P4000??? Help!
    Hi Shar103 and welcome to the forums. Although unsupported the 1080 might work with MC, You'll have to find a driver release Avid friendly (and 3dS-AE friendly...). This has been discussed plenty over the forums, please run a search for additional information.
    peace luca
  • Sat, Nov 3 2018 10:46 AM In reply to
    • CeeBee
    • Joined on Mon, Sep 5 2016
    • Posts 22
    • Points 260
    I chose the 1080ti  and it boost my avid system, expecially when i work with xavc-i 4k - now i am able to play it back smooth.
    I m not sure about 3d studio - but after effects will also love the 1080ti.
    i guess your ssd will be to small - if you use a 1 tb you could also use the c-drive for a cache drive. but 500gb you need at least for your programs.
    cheers
    c.
  • Sat, Nov 3 2018 1:52 PM In reply to
    • Shar103
    • Posts 3
    • Points 25
    Thanks, If the 1080 ti works I'm put the money into a bigger ssd hard drive.
  • Sat, Nov 3 2018 1:53 PM In reply to
    • Shar103
    • Posts 3
    • Points 25
    Thanks for the driver info.  I'll do a search.
