Latest post Fri, Nov 2 2018 5:17 PM by Rich Laws. 2 replies.
  • Fri, Nov 2 2018 4:52 PM
    • Rich Laws
    • Joined on Wed, Oct 17 2012
    • Posts 95
    • Points 905
    AMT AssetInfoHandler error with a cut range explanation?
    Hi all,
    Has anyone seen this error with AMT3 (4.4.19.10039)
    This occurs with SOME clips while I am attempting to extract frames from a source.  In this case, I have a 7200 frame 1280x720p59.94 clip.  If I attempt a read with a cut from frame 0 to 50, it is ok.  attempt 100 to 150 for instance I get this error:
    error: 5004, detail: ..\..\MediaProcessor\src\MediaProcessor\AssetInfoHandler.cpp, 570: cutRange.start () >= 0 && (cutRange.start () < displayRange.length () || displayRange.length () < 0): Invalid cut start position.
    Seems to occur with 23.976p and 59.94p clips... Still experimenting but I am hoping someone has a suggestion. Essence Info and MAD for source is below: ESSENCE INFO: <?xml version="1.0" encoding="UTF-8" standalone="no" ?> <mpei:EssenceInfo xmlns:mpei="urn:AVID:MediaProcessor:EssenceInfo" xmlns:mpct="urn:AVID:MediaProcessor:CommonTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:AVID:MediaProcessor:EssenceInfo EssenceInfo.xsd">   <mpei:ContainerInfo>     <mpei:ContainerKind>Avid OP Atom</mpei:ContainerKind>     <mpei:Duration>7200</mpei:Duration>     <mpei:EditRate>       <mpct:Numerator>60000</mpct:Numerator>       <mpct:Denominator>1001</mpct:Denominator>     </mpei:EditRate>     <mpei:StartOfMedia>       <mpct:RoundedTimecodeBase>60</mpct:RoundedTimecodeBase>       <mpct:FrameCounter>10810</mpct:FrameCounter>       <mpct:DropFrame>true</mpct:DropFrame>     </mpei:StartOfMedia>     <mpei:StartOfFile>0</mpei:StartOfFile>   </mpei:ContainerInfo>   <mpei:PAMInfo>     <mpei:PhysicalSourceMobOffset>0</mpei:PhysicalSourceMobOffset>     <mpei:TapeDescriptorInfo>       <mpei:DescriptorType>TapeDescriptor</mpei:DescriptorType>       <mpei:TapeName>BE922D8003D011E5870000012953736F</mpei:TapeName>     </mpei:TapeDescriptorInfo>     <mpei:PhysicalSourceMobID>060a2b340101010501010d2313-a10000-be27e0f93695494f-a8c817a7656d-1517</mpei:PhysicalSourceMobID>     <mpei:MasterMobID>060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80</mpei:MasterMobID>   </mpei:PAMInfo>   <mpei:Tracks>     <mpei:PictureTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517v01.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>1</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:PictureEssenceEncodingFamily>MPEG-4 Part 10</mpei:PictureEssenceEncodingFamily>       <mpei:PictureEssenceEncoding>XAVC-Intra 100</mpei:PictureEssenceEncoding>       <mpei:PictureEssenceEncodingName>XAVC-Intra 100</mpei:PictureEssenceEncodingName>       <mpei:VideoBitRate>113428000</mpei:VideoBitRate>       <mpei:Colorspace>YUV 709</mpei:Colorspace>       <mpei:FrameLayout>Full Frame</mpei:FrameLayout>       <mpei:ImageWidth>1280</mpei:ImageWidth>       <mpei:ImageHeight>720</mpei:ImageHeight>       <mpei:ImageAspectRatio>         <mpct:Numerator>16</mpct:Numerator>         <mpct:Denominator>9</mpct:Denominator>       </mpei:ImageAspectRatio>       <mpei:ColorSubsampling>4:2:2</mpei:ColorSubsampling>       <mpei:BitDepth>10</mpei:BitDepth>       <mpei:MinRefLevel>64</mpei:MinRefLevel>       <mpei:MaxRefLevel>940</mpei:MaxRefLevel>       <mpei:ColorRange>897</mpei:ColorRange>       <mpei:CodingEquations>06.0e.2b.34.04.01.01.01.04.01.01.01.02.02.00.00</mpei:CodingEquations>     </mpei:PictureTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a01.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>2</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a02.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>3</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a03.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>4</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a04.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>5</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a05.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>6</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a06.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>7</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a07.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>8</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>     <mpei:SoundTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:MediaFile>N:\NLT Nearchive Files\Assets\1\060a2b340101010101010f0013-000000-1715953627bef9e0-060e2b347f7f-2a80\clip00009_be27e0f936951517a08.mxf</mpei:MediaFile>       <mpei:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:SampleRate>       <mpei:PhysicalSourceMobTrackIds>         <mpct:TrackID>9</mpct:TrackID>       </mpei:PhysicalSourceMobTrackIds>       <mpei:BoundedEditUnitSize>0</mpei:BoundedEditUnitSize>       <mpei:SoundEssenceEncodingFamily>Uncompressed</mpei:SoundEssenceEncodingFamily>       <mpei:SoundEssenceEncoding>Uncompressed</mpei:SoundEssenceEncoding>       <mpei:SoundEssenceWrapping>AES-3 ST 382</mpei:SoundEssenceWrapping>       <mpei:SoundEssenceEncodingName>PCM</mpei:SoundEssenceEncodingName>       <mpei:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpei:AudioSamplingRate>       <mpei:ChannelCount>1</mpei:ChannelCount>       <mpei:QuantizationBits>24</mpei:QuantizationBits>       <mpei:BitRate>1152000</mpei:BitRate>     </mpei:SoundTrack>   </mpei:Tracks>   <mpei:PhysicalSourceMobTracks>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>1</mpei:TrackID>       <mpei:PhysicalTracknumber>1</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>2</mpei:TrackID>       <mpei:PhysicalTracknumber>1</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>3</mpei:TrackID>       <mpei:PhysicalTracknumber>2</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>4</mpei:TrackID>       <mpei:PhysicalTracknumber>3</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>5</mpei:TrackID>       <mpei:PhysicalTracknumber>4</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>6</mpei:TrackID>       <mpei:PhysicalTracknumber>5</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>7</mpei:TrackID>       <mpei:PhysicalTracknumber>6</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>8</mpei:TrackID>       <mpei:PhysicalTracknumber>7</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>     <mpei:PhysicalSourceMobTrack>       <mpei:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpei:EditRate>       <mpei:TrackID>9</mpei:TrackID>       <mpei:PhysicalTracknumber>8</mpei:PhysicalTracknumber>     </mpei:PhysicalSourceMobTrack>   </mpei:PhysicalSourceMobTracks> </mpei:EssenceInfo> MAD: <?xml version="1.0" encoding="UTF-8" standalone="no" ?> <mpmad:MediaAssetDescription xmlns:mpmad="urn:AVID:MediaProcessor:MediaAssetDescription" xmlns:mpct="urn:AVID:MediaProcessor:CommonTypes" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:AVID:MediaProcessor:MediaAssetDescription MediaAssetDescription.xsd">   <mpmad:PreCharge>     <mpct:Numerator>0</mpct:Numerator>     <mpct:Denominator>1</mpct:Denominator>   </mpmad:PreCharge>   <mpmad:Duration>     <mpct:Numerator>3003</mpct:Numerator>     <mpct:Denominator>25</mpct:Denominator>   </mpmad:Duration>   <mpmad:Tracks>     <mpmad:PictureTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627c0f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:PictureEssenceEncoding>XAVC-Intra 100</mpmad:PictureEssenceEncoding>       <mpmad:VideoBitRate>113428000</mpmad:VideoBitRate>       <mpmad:CompressedData>         <mpmad:ColorModel>YUV</mpmad:ColorModel>         <mpmad:ComponentDepth>10</mpmad:ComponentDepth>         <mpmad:HorizontalSubsampling>2</mpmad:HorizontalSubsampling>         <mpmad:VerticalSubsampling>1</mpmad:VerticalSubsampling>       </mpmad:CompressedData>       <mpmad:CDCIData>         <mpmad:BlackRefLevel>64</mpmad:BlackRefLevel>         <mpmad:WhiteRefLevel>940</mpmad:WhiteRefLevel>         <mpmad:ColorRange>897</mpmad:ColorRange>         <mpmad:ColorSiting>4</mpmad:ColorSiting>       </mpmad:CDCIData>       <mpmad:FrameLayout>0</mpmad:FrameLayout>       <mpmad:SampledTopness>1</mpmad:SampledTopness>       <mpmad:StoredWidth>1280</mpmad:StoredWidth>       <mpmad:StoredHeight>720</mpmad:StoredHeight>       <mpmad:SampledWidth>1280</mpmad:SampledWidth>       <mpmad:SampledHeight>720</mpmad:SampledHeight>       <mpmad:SampledXOffset>0</mpmad:SampledXOffset>       <mpmad:SampledYOffset>0</mpmad:SampledYOffset>       <mpmad:DisplayWidth>1280</mpmad:DisplayWidth>       <mpmad:DisplayHeight>720</mpmad:DisplayHeight>       <mpmad:DisplayXOffset>0</mpmad:DisplayXOffset>       <mpmad:DisplayYOffset>0</mpmad:DisplayYOffset>       <mpmad:VideoLineMap>         <mpmad:Line>26</mpmad:Line>         <mpmad:Line>0</mpmad:Line>       </mpmad:VideoLineMap>       <mpmad:DisplayAspectRatio>         <mpct:Numerator>16</mpct:Numerator>         <mpct:Denominator>9</mpct:Denominator>       </mpmad:DisplayAspectRatio>       <mpmad:CodingEquations>06.0e.2b.34.04.01.01.01.04.01.01.01.02.02.00.00</mpmad:CodingEquations>     </mpmad:PictureTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627c2f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627c4f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627c6f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627c8f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627caf9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627ccf9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627cef9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>     <mpmad:SoundTrack>       <mpmad:EditRate>         <mpct:Numerator>60000</mpct:Numerator>         <mpct:Denominator>1001</mpct:Denominator>       </mpmad:EditRate>       <mpmad:SampleRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:SampleRate>       <mpmad:FramePreCharge>         <mpct:Numerator>0</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:FramePreCharge>       <mpmad:FileMobID>060a2b340101010101010f0013-000000-1715953627d0f9e0-060e2b347f7f-2a80</mpmad:FileMobID>       <mpmad:SoundEssenceEncoding>Uncompressed</mpmad:SoundEssenceEncoding>       <mpmad:SoundEssenceWrapping>AES-3 ST 382</mpmad:SoundEssenceWrapping>       <mpmad:AudioSamplingRate>         <mpct:Numerator>48000</mpct:Numerator>         <mpct:Denominator>1</mpct:Denominator>       </mpmad:AudioSamplingRate>       <mpmad:ChannelCount>1</mpmad:ChannelCount>       <mpmad:QuantizationBits>24</mpmad:QuantizationBits>       <mpmad:WaveData>         <mpmad:BlockAlign>3</mpmad:BlockAlign>         <mpmad:AvgBytesPerSecond>144000</mpmad:AvgBytesPerSecond>       </mpmad:WaveData>     </mpmad:SoundTrack>   </mpmad:Tracks>   <mpmad:StartTimecode>     <mpct:RoundedTimecodeBase>60</mpct:RoundedTimecodeBase>     <mpct:FrameCounter>10810</mpct:FrameCounter>     <mpct:DropFrame>true</mpct:DropFrame>   </mpmad:StartTimecode>   <mpmad:MaterialName>Sxs AVCHD50mb 720p60</mpmad:MaterialName> </mpmad:MediaAssetDescription>
  • Fri, Nov 2 2018 5:12 PM In reply to
    • Rich Laws
    • Posts 95
    • Points 905
    Re: AMT AssetInfoHandler error with a cut range explanation?
    So.. here is a clue...  Are there rules to use for the RationalNumber used for cut information.
    To get an accurate calculation for the non- whole number frame counts, I was doing this (for example)
    Rational numerator = frame * 1001, Rational denominator = 60000
    cut start =   offset*1001 / 60000   (fails)
    If I use frame / 60 - I don't get the error.
  • Fri, Nov 2 2018 5:17 PM In reply to
    • Rich Laws
    • Posts 95
    • Points 905
    Please disregard - we have determined root cause - our error... Sorry!  Embarrassed
