Latest post Mon, Nov 19 2018 2:25 PM by mult1. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Oct 31 2018 11:34 AM
    • mult1
    • Joined on Wed, Oct 31 2018
    • Posts 4
    • Points 30
    MC 2018.8 Problems saving Bins from older Version: Assertion failed
    Hi there,
    we're having some huge problems with Media Composer 2018.8.
    We have around 20 edit suites and are upgrading our whole facility from 8.4.5 to 2018.8. This takes quite a while. Unfortunately a lot of bins created in 8.4.5 raise an error in 2018.8 after you changed something inside the bin and then closing / saving it. The error is:
    Assertion failed: iter != sWindowList.end ()
    File s:\ppg\mediacomposer\media_composer\mcwindowsmenuutils.cpp, Line:141
    The bins do not save and we cannot close them. Any suggestions here? We cannot migrate huge projects by creating a new project in 2018.8 and duplicate every content to a new bin. We need to work simultaneously on 2018.8 and 8.4.5.
    Beste wishes
    mult1
  • Wed, Oct 31 2018 6:51 PM In reply to
    • Posts 10,219
    • Points 218,265
    Re: MC 2018.8 Problems saving Bins from older Version: Assertion failed
    Multi
    Can you email me at least one of the system ID's and the MyAvid email this is associated with.
  • Fri, Nov 2 2018 8:46 AM In reply to
    • mult1
    • Posts 4
    • Points 30
    Hi Marianna,
    thanks for your reply. You got an e-mail with the adress and one sys-ID.
    Kind regards,
    Mult1
  • Fri, Nov 2 2018 11:40 PM In reply to
    Hi Marianna
    We just started testing this verison today and got the same errors as described above.
    Are there any notes from avid regarding a fix for this or at least a work around?
  • Sat, Nov 3 2018 7:48 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    A shot in the dark: what if You trash the project settings? Make a backup copy first, just in case. Also, are You carrying over user settings from MC 8.4.5 to MC 18.8? If yes try with fresh new user settings instead.
    peace luca
  • Mon, Nov 5 2018 1:42 PM In reply to
    • mult1
    • Posts 4
    • Points 30
    I tested both. I created a new project on 2018.8 and just took some bins from the 8.4.5 project. Happens there too. Also 2018.8-user-settings are causing this error....
  • Mon, Nov 19 2018 2:25 PM In reply to
    • mult1
    • Posts 4
    • Points 30
    Marianna:
    Multi
    Hi marianna,
    I never got an reply from you regarding this topic. Is there any chance of fixing or workaround?
    Best wishes
    mult1
