Latest post Sat, Nov 17 2018 9:38 PM by mPepe. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Oct 26 2018 5:09 PM
    • kd-53
    • Joined on Wed, Apr 28 2010
    • Duesseldorf, Germany
    • Posts 23
    • Points 310
    MC 2018.10 crashes when exporting quicktime reference
    today I switched from MC 2018.8 to MC 2018.10. Everything worked fine until I tried to export the final sequence to a qicktime reference. MC finished with an exeption. It is a UHD project 25p, video and audio are mixdowns. I tried it with other files and other project settings (1080 25i). Same result. I closed MC and rebooted the system. Same result.
    So I switched back to MC 2018.8. Now the export works fine with the same sequence. This seems to be a bug. Does anyone have the same problem? In the near future I will stay on MC 2018.8.
    Best regards
    Kl
    aus-Dieter
    Mobo: Asus Z270-A, i7-7700K, 32GB Ram, Win 10 Prof 64, GeForce GTX 1060 with 6 GB Ram, BM Intensity Pro 4K, MC 2018.8, BCC11, 2 x 24" monitors, Sony... [view my complete system specs]
  • Sat, Oct 27 2018 8:31 AM In reply to
    • kd-53
    • Posts 23
    • Points 310
    Re: MC 2018.10 crashes when exporting quicktime reference
    this is the error message I received:
  • Sat, Oct 27 2018 9:14 AM In reply to
    • gswilson
    • Joined on Thu, Feb 4 2010
    • Belfast, Ireland - now, Frankfurt am Main, Germany
    • Posts 315
    • Points 4,135
    I'm seeing the same exception error message when trying to export a QT Ref. and I filled out the message panel and sent it to Avid.
    I can export a QT Ref for Squeeze without any issues when I select Sorenson Squeeze from the export options.
    Gerry
    MC 2018.12.1, Win 10 Pro(1809), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, Nvidia GTX 1080Ti GPU(Driver 417.35),Samsung 850 Pro 512... [view my complete system specs]
  • Sat, Oct 27 2018 9:20 AM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 140
    • Points 1,725
    I have the same experience with 2018.10.
    MacBook Pro (Retina, 15-inch, Mid 2014), 2,8 GHz Intel Core i7, NVIDIA GeForce GT 750M 2048 MB, OSX 10.11.6 [view my complete system specs]
  • Sat, Oct 27 2018 12:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,623
    • Points 60,385
    Yes - this is a bug. Switch your audio output to WAVE format in the QT Ref settings. Very odd that this got past SQA but at least there is a workaround.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Oct 27 2018 2:18 PM In reply to
    • gswilson
    • Posts 315
    • Points 4,135
    Thanks for the workaround Steve. Really wierd that something like this could slip through testing.
    Gerry
  • Sat, Nov 17 2018 9:38 PM In reply to
    • mPepe
    • Joined on Sat, Dec 2 2017
    • Posts 1
    • Points 5
    I'm experiencing the same problem. I get an "Alert" that says: "Segmentation fault" in thread "MainThread", at address   0x0
    Then MC crashes. It creates a .mov file that is not supported in Squeeze.
    And yes, as suggested elsewhere changing the audio output to Wave did the trick. The .mov file then imported into Squeeze.
