Latest post Wed, Dec 19 2018 8:21 PM by Arnoud. 25 replies.
Page 1 of 2 (26 items) 1 2 Next >
  • Wed, Oct 24 2018 9:36 PM
    Segmentation error on trimming 2018.10.0
    Hello:
    Every time I grab video with the trim roller and try to manually roll the edit, I get a crash.  I'm on a MacPro5,1 tower, (mid 2010), on High Sierra 10.13.4.  This worked fine on 2018.9.0, which I was using earlier today, same project, DNxHD36 media.
    I've included the splash screen I see on crash.  Is it me, or a bug?
    Thanks, JIM.
    MC 2018.10 Sierra 10.13.4 Westmere Octo 3.46 Mhz 48 GB RAM EVGA GTX 970 FTW GPU SATA RAID array BM DeckLink Mini Monitor 4K [view my complete system specs]
    JAMES BLOKLAND
  • Thu, Oct 25 2018 12:58 AM In reply to
    Re: Segmentation error on trimming 2018.10.0
    Here's a more detailed capture of the crash.
    Anyone?
    Thanks, JIM.
    JAMES BLOKLAND
  • Thu, Oct 25 2018 5:46 PM In reply to
    • Posts 10,087
    • Points 216,565
    Jim
    So this popped up after you installed 2018.10?
    Let me get a case started.
  • Thu, Oct 25 2018 6:03 PM In reply to
    Hi Marianna!
    Yes, nothing else has changed except the MC build.  On 2018.09, it worked as it always has.  Now on 2018.10, every time (and I mean EVERY time) I grab a piece of media and try to manually roller trim on the timeline, AVID crashes.
    Thanks for starting the case.  I might have to roll back to 2018.09 in the meantime, just so I can get some work done!
    Best, JIM.
    JAMES BLOKLAND
  • Thu, Oct 25 2018 6:06 PM In reply to
    Oh, I should also mention, it doesn't matter if I have the BM DeckLink engaged or not, or whether the CAPS LOCK is on, it crashes all the same.
    Best, JIM.
    JAMES BLOKLAND
  • Thu, Oct 25 2018 9:31 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 726
    • Points 8,595
    @Jim Blokland: can you attach a crash log from Console?
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Demo ReelTwitter | Instagram | Vimeo
    Writer: The Frame.io Workflow Guide - http://workflow.frame.io/
    Post-production and Workflow Consultant - https://isaact.co/
  • Thu, Oct 25 2018 9:57 PM In reply to
    Hi Isaac:
    I couldn't get it to export the log from Console after the crash, but I exported before the crash, and did a screen capture of the last few lines on the console after the crash.
    Hope this helps.
    Best, JIM.
    JAMES BLOKLAND
  • Thu, Oct 25 2018 9:58 PM In reply to
    Here's the screen grab.
    JAMES BLOKLAND
  • Fri, Oct 26 2018 4:38 PM In reply to
    • Isaac T.
    • Posts 726
    • Points 8,595
    @Jim Blokland: Stick out tongue Haha! I thought that would happen.
    That is, can you attach a crash log from macOS' Console?
    /Applications/Utilities/Console.app -> User Reports -> should see some Media Composer reports ending in .crash. Select one, then right-click -> "Reveal in Finder". Attach a few. Should be small enough for the forum.
    Sorry. That's on me.
  • Fri, Oct 26 2018 4:52 PM In reply to
    Thanks Isaac!  here ya go...
    JAMES BLOKLAND
    And another one...
    JAMES BLOKLAND
  • Fri, Oct 26 2018 6:44 PM In reply to
    • Isaac T.
    • Posts 726
    • Points 8,595
    Hey Jim,
    Can you try this?
    1. Duplicate your sequence.
    2. Reset everything for those audio clips - levels at 0dB, remove effects, remove transitions, remove any keyframes, etc.
    3. Try to trim again.
    Still crashing?
  • Fri, Oct 26 2018 8:49 PM In reply to
    Hey Isaac:
    Thanks for this.  Removed all levels, effects, keyframes from the sequence.  Rolled a whole bunch of bits around – audio, video, slides, etc – no crashes.
    Of course, as you're no doubt aware, I need all those things in my sequence...and in all previous version of the software, was able to trim with no issues.
    Thanks for troubleshooting.  Let me know if there's anything else you need.
    Best, JIM.
    JAMES BLOKLAND
  • Fri, Oct 26 2018 9:46 PM In reply to
    • Isaac T.
    • Posts 726
    • Points 8,595
    @Jim Blokland:
    Jim Blokland:
    OK, good.
    Looking at the crash logs, it looks like a bug. Also seems to be a recurring item. Given your workstation has macOS 10.12.6 (not OS X 10.9.5), and it happens whether or not your BMD hardware's connected, it looks like this is related to audio in the timeline.
    According to this thread:
    https://community.avid.com/forums/p/161226/813283.aspx
    It could be...
    1. Both keyframes and a dissolve were applied to that audio clip.
    2. An unrendered dissolve on an audio clip.
    If that's true, try adding-and-rendering a dissolve. If that's successful, try adding any other mixing or finishing bits, one-by-one. My hunch is MC will crash if you keyframe and add a dissolve the clip, then attempt to trim.
    Also see:
    • https://community.avid.com/forums/p/137776/813500.aspx#813500
    • https://community.avid.com/forums/p/137776/853558.aspx#853558
    Keep us posted!
  • Sun, Oct 28 2018 1:42 AM In reply to
    • TaT
    • Posts 44
    • Points 555
    I can confirm... very annoying bug... after upgrade to AMC 2018.10 I trashed my settings files then trimming with mouse works as usual. After 2 hours, when I moved trim rollers with mouse, disaster begins... then I trash my settings files again and everything works OK but after another 3 hours - CAPS LOCK on (audio scrubbing) and attempt to trim with mouse... bang....  Angry
    Mac Pro (Late 2013) 6 Core 3.5GHz, Avid MC 2018.12, 64GB RAM, D500, OS 10.13.6 *** PC X99 mobo 6 Core 4.2GHz, Avid MC 2018.12, 64GB RAM, GTX 970, Windows... [view my complete system specs]
