Latest post Fri, Mar 8 2019 6:54 PM by John Moore. 37 replies.
Page 1 of 3 (38 items) 1 2 3 Next >
  • Wed, Oct 24 2018 4:57 PM
    Idea [I] Media Composer v2018.10 -- AVAILABLE -- w/ Mojave support
    Avid is pleased to announce the latest release of Media Composer v2018.10 on October 24th, 2018. The software is available through My Avid, Avid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.
    + OS SUPPORT:
    This release adds support for macOS 10.14 (Mojave), while including macOS 10.13.6 (High Sierra) as well as 10.12.6 (Sierra), and 10.11.6 (El Capitan).
    + NEW FEATURES:
    - Additional AVC-LongG formats are supported
    - Color Management LUT Fix
    - Additional Color Space Presets
    + MOJAVE USERS:
    Please note you may experience a significant delay in trying to install the application the first time, and the Finder may hang. Allow the process to complete after several minutes and you should be able to install successfully.
    + NITRIS DX/MOJO DX USERS:
    Please note the DX driver is NOT automatically selected in the install process.
    Within the MC installer, when you get to Installation Type, be sure to select the Avid DX Driver under Media Composer Editing Application.
    + BUG FIXES:
    This release addresses 40 bugs since the last release, including:
    - In some instances, Media Creation settings may not have remain the same after closeing and opening the project.
    - Audio may have been out of sync when linking ProRes 422 files
    - Exporting an h.264 file as stereo did not export in stereo
    - In some instances, you could not scroll while perofrmaing playback in the timeline
    - Trim to Fill did not work on clips with a spatial adapter
    - If you had Boris FX Final Effects Complete installed, you may have had problems with Open I/O devices
    - Intermittently, the position bars under the source and record monitors did not move
    + FOR MORE INFORMATION:
    See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.
    If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
  • Wed, Oct 24 2018 8:24 PM In reply to
    • wolfgang
    • Joined on Fri, Sep 17 2010
    • vienna, austria
    • Posts 48
    • Points 545
    Re: Media Composer v2018.10 -- NOW AVAILABLE -- with Mojave support
    what about 10.13.6 ?
    macpro 5,1 12-core 2 x 3,46GHz, 96GB/2 x 2TB SSD/2 x 1TB SSD/16TB HD/AMD vega64/BMD decklink 4k extreme 2 x EizoFX2431 macbookpro 15"retina 2017 3... [view my complete system specs]
  • Wed, Oct 24 2018 8:29 PM In reply to
    Sorry...I copied that from an older post and missed that. 10.13.6 is qualified; I changed the post to reflect that.
  • Thu, Oct 25 2018 12:09 AM In reply to
    any word on a blackmagic / Aja fix?
    If so for BMD - which driver should we be on at this point?
    iMAC (late 2015) 4GHZ i7 - 32GB RAM - AMD R9 M395X 4GB 512 SSD BOOT BM Ultra Studio Express w/Driver 10.5.4. [view my complete system specs]
  • Thu, Oct 25 2018 8:31 AM In reply to
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 273
    • Points 3,595
    Robert Goodman :
    here Marianna wrote  864413.aspx
    my zoo: NEXIS Pro 40 tb sw v18.6.1; MBPro_late_2013 15'' i7 16GBram OSX 10.12.6 MC 2018.12.1 BMD US monitor (or AJA io XT ), EXT thunderbolt NvidiaGPU... [view my complete system specs]
    DJFio[DB]
  • Thu, Oct 25 2018 12:49 PM In reply to
    [quote user="DJFio[DB]"]
    Robert Goodman :
    [/quote]
    Thank you jut noticed BM released new drivers yesterday. tried these with 2018.10 and Mojave and everything seems ok on the surface.
  • Thu, Oct 25 2018 1:28 PM In reply to
    • Posts 10,204
    • Points 218,070
    Terrific news!!!!  Thanks for the status update as I wondered if anyone was going to comment.
    Whooo hoooo  Aja is working too.
  • Thu, Oct 25 2018 10:20 PM In reply to
    • pierreh
    • Paris, London
    • Posts 1,216
    • Points 14,725
    Kevin Klimek:
    + OS SUPPORT:
    In the past, this kind of announcement always came a day or so before Apple updates their OS. Is 10.4.1 coming tomorrow? Big Smile
  • Thu, Oct 25 2018 11:09 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 273
    • Points 3,595
    After 12hour testing with heavy timeline , BMD mini monitor and NEXIS -
    1)2018.10 - is pretty much more responsive than all previous versions in multicam editing.
    2)continuous BMD playback is smoother than in many  previous versions
    3)Very stable version - no crashes
    4)Once happened - my blue position bar stopped moving  ( Bug Number: MCDEV-9676.) but in a minute works again - after app switch to desktop and back
    5)"Live timeline" in this version is more attractive and responsive
    6)"hide video" in source record monitor - does something weird
    7)NDi multicam mode playback - doesn't work. (tried just for fun)
    UPD:
    8)some interesting UI glitches introduced in this version -
    something like
    - if you drop many files in a bin to import - during import each new line in bin displays gfxtrash for a second
    - (once happened) red and yellow smart tool arrows (cursors) are not displayed while not dragging a segment  (FIX- restart app)
    9)blue timeline -position bar disappears (i can't see it on timeline) more often than in prev versions (FIX- restart app)
    10) in right click menu on timeline sometimes doesn't work 2nd level nested menus (at the same time when blue bar disappears or doesn't move) (FIX- restart app)
    11)sometimes  when i move mouse fast between windows up and down (timeline and source record mon for instance) application shows me a right-click menu. (FIX- restart app)
    DJFio[DB]
  • Fri, Oct 26 2018 7:30 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 273
    • Points 3,595
    looks like developers speeded up some UI things, but  some other new UI glitches was introduced too %)
    DJFio[DB]
  • Wed, Oct 31 2018 8:44 AM In reply to
    • Arnoud
    • Joined on Sun, Dec 6 2015
    • Kwant
    • Posts 26
    • Points 295
    Well... All seemed to be well at first. But this version seems to hate it if I drag-trim a cut in the timeline. It crashes a lot. I've tried avoiding this by trimming with the keyboard, but dragging is very much a part of how I work. So sometimes I automatically drag a cut and BAM, it crashes (not everytime but a lot). I consider downgrading again.
    Arnoud
    PC with Intel i9-7920X 2.90 Ghz processor, 64 Gb RAM, Nvidia Georce 2080ti GPU, running Windows 10 pro and iMac (Retina 5K, 27-inch, Late 2014) 4 GHz... [view my complete system specs]
  • Wed, Oct 31 2018 12:15 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 64
    • Points 865
    Arnoud:
    Hi Arnoud,
    have you seen this thread?: http://community.avid.com/forums/t/185854.aspx
    Sounds like the problem you are having - and that it is being taken care of.
  • Wed, Oct 31 2018 12:25 PM In reply to
    • Arnoud
    • Kwant
    • Posts 26
    • Points 295
    Cutyes:
    Arnoud:
    Hi Arnoud,
    No, I hadn't. Thank you Cutyes. I was already doubting my Wacom driver, because I updated that at the same time! But now I now it's in this MC build.
    Cheers,
    Arnoud
  • Tue, Nov 6 2018 2:55 PM In reply to
    • Pedrodor
    • Joined on Tue, Nov 6 2018
    • Posts 2
    • Points 10
    And what about 10.14.1? I bought Avid Media Composer Ultimate today and it installed quickly and well. But when i'm opening it crashes and quits. During initializing AMPIpluginDSM. Please, answer me.
  • Tue, Nov 6 2018 2:59 PM In reply to
    • Pedrodor
    • Posts 2
    • Points 10
    I have Mojave 10.14.1. It crashes and quits during initializing AMPIPluginsDSM. What happened?
