Latest post Mon, Oct 29 2018 1:16 PM by Rich Laws. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Oct 23 2018 1:29 PM
    • Tsachi
    • Joined on Tue, Oct 23 2018
    • Posts 2
    • Points 30
    AMT3: Interplay checkin errors
    Hello,
    We tested the checkin procedure to interplay using the Demo application of the new AMT3.0 SDK itself.
    The sample application from Avid has the name “MediaProcessor.Demos.exe”.
    We also used a sample clip from Avid itself (is inside the AMT package).
    This is the error log from the Application:
    INFO - ..\..\MediaProcessor\src\MediaProcessor\DataIO\SOAPRequest.cpp, line: 501: SOAP request finished. Execution took 81ms.
    ERROR - InterplayWebServicesNotificationChannel[interplay://ccpostwg/Incoming Media/Genesix] WebService request failed: ..\..\MediaProcessor\src\MediaProcessor\Notifications\InterplayWebServicesNotificationChannel.cpp, 116: Failed to locate 'CheckInAAFResponse' element in the SOAP response body..
    And we get this error message by calling the webservice:
    Next we tried to call this function “CheckInAAF” directly from the webservice.
    This error message we receive from the Avid webservice by calling this function:
    We are thinking that the Avid system is not correctly setup and that is why we cannot check in clips.
    Any idea what we should look for into Avid Interplay settings?
  • Tue, Oct 23 2018 2:14 PM In reply to
    • andym
    • Joined on Thu, Jan 13 2011
    • Posts 103
    • Points 1,215
    • Avid Developer Moderator
    Re: AMT3: Interplay checkin errors
    Tsachi,
    as mentioned in my posting to a similar question, please use a toolkit such as SOAPUI to validate that your Interplay Web Services instance is operational and that you have valid credentials etc at hand. You can do this in SOAPUI or similar tools by executing the CheckinAAF() SOAP call in the IPWS Assets realm. You can use SOAPUI to exercise and validate other IPWS functions to get a better understanding on how IPWS operate. Once you have successfully performed a 'manual' checkin operation using the SOAP API, you can assume your IPWS instance and your credentials to be valid and can supply the same parameters though AMT3.
    The error messages above sound like an installation problem so it is important to validate that your infrastructure is operational. This may require having an Avid Shared Storage environment (ISIS, NEXIS) available.
  • Tue, Oct 23 2018 2:22 PM In reply to
    • andym
    • Posts 103
    • Points 1,215
    BTW, the problem showing in the error messages does not seem like it is settings related, rather this appears to be an incomplete installation.
    For successfully performing an AAF checkin using Interplay Web Services and working with the media, you need at least the following items installed and configured:
    • Media Central Production (Interplay) Engine - the database
    • Media Central Production (Interplay) Web Services - the SOAP API
    • Media Central Production Index (Media Indexer) - provides media status
    • ISIS or NEXIS storage - shared storage compatible with Production database
    • ISIS or NEXIS client on the machines that performs the checkin - enables access to shared storage
    • Access client on the machine performing the ingest - database access libraries and management UI
    • Media Composer, MediaCentral or CloudUX for playing back the video
  • Thu, Oct 25 2018 4:49 PM In reply to
    • Rich Laws
    • Joined on Wed, Oct 17 2012
    • Posts 87
    • Points 835
    Hi Tsachi,
    We are a 3rd party developer and by no means am I responding on behalf of Avid or as an expert on the internals of IPWS.
    It may be worth trying IPWS 3.80 or IPWS 20172.  This is just a suggestion based on seeing the same error in our test lab with some newer IPWS versions (eg IPWS 20186).  To work around we currently test with IPWS 3.80 and IPWS 20172.   We do not have any problems with these versions.   Admittedly we have not spent a lot of time trying to understand the issue, we are just using an older IPWS version.
    Good luck!
    Rich Laws
  • Thu, Oct 25 2018 10:37 PM In reply to
    • Tsachi
    • Posts 2
    • Points 30
    Hi Rich,
    Eventually downgrading to 2017.2 were solve this issues.
    Tsachi
  • Mon, Oct 29 2018 1:16 PM In reply to
    • Rich Laws
    • Posts 87
    • Points 835
    Hi Tsachi,
    Glad to hear that you were able to solve this!
    Rich
