Latest post Sat, Oct 20 2018 7:08 PM by Ryan Rigley. 4 replies.
  • Thu, Oct 18 2018 6:08 PM
    Having a major audio issue with Avid Media Composer First, please help
    here is a link to the video file I posted on Reddit showing the situation
    Sorry in advanced for the watermark on the example video (too cheap to buy a screen recording program that grabs system audio).
    I'm having a problem with Avid, when I cut any sort of audio clip and put part of it on a different track; there is a slight break in audio playback that sounds like it's missing a frame of the audio clip. This does not happen when both clips are on the same track, only when they are separated. Why is this happening??
    the video shows these events:
    • audio playback works with uncut clip
    • audio playback works with cut clip on same track
    • audio playback skips when cut clip is on two different tracks.
  • Sat, Oct 20 2018 5:43 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,517
    • Points 64,020
      Moderator: MCA Mac
    Re: Having a major audio issue with Avid Media Composer First, please help
    Check the sample rate on the clips and see if they need to be converted to the project sample rate.
  • Sat, Oct 20 2018 6:13 PM In reply to
    sorry for being so dumb, How would I go about checking the project sample rate? Right now all I can see is that the sequence im working in is set to 1280 HD at 23.976.
    also the music file I'm using is a AIFF file at 48k 16bit
  • Sat, Oct 20 2018 6:35 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 363
    • Points 4,760
    You can check the project sample rate in Settings>Audio Project Settings.
    If you right-click on the sequence in your bin and select Audio>Change Sample Rate, you can convert all the clips to your project rate.
    Not sure if this is the cause of your issue, but it's worth a try.
    Avid Media Composer 2018.12 Symphony option, Avid Artist DNxID on macOS 10.14.2, iMac Pro (2017) 10-Core, 3.0GHz Intel Xeon W, Turbo Boost up to 4.5GHz... [view my complete system specs]
  • Sat, Oct 20 2018 7:08 PM In reply to
    sadly I am using Media Composer| First, so both :
    and Audio>Change Sample Rate
    arent options that show up for me
