Latest post Tue, Oct 16 2018 5:25 AM by Ulrich Thomsen. 4 replies.
  • Sat, Oct 13 2018 10:36 AM
    won't export selected tacks
    Hi
    Im trying to export a Boris FX Tilte on a seperate tack as a quicktime. Track 3 is only slected . I check 'use selected tracks' in the quicktime settings but it does a mix down of all video traks
    Am I missing something
    best Ulrich
    Media Composer 2018.5 Mac Pro, late 2013, 2.7 GHZ 12 Core Intel Xeon E5 64 GB 1867 Mhz DDR3 memory AMD FirePro D700 6144 MB [view my complete system specs]
  • Sat, Oct 13 2018 10:27 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 210
    • Points 2,190
    Re: won't export selected tacks
    That is normal behaviour, if you want to only see the title you could mute the clips underneath or subclip it out and export the subclip.
    If you command click on the track view icon you “solo” the track  (the track view icon goes green) ,that may work too?
  • Sun, Oct 14 2018 2:00 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,251
    • Points 39,455
    Ulrich Thomsen:
    As the other response gave some ways to address what you are "seeing", please know that any export from Media Composer will NOT have an alpha channel.  That is not supported.  You will only get the fill as a full screen image.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." | OS 10.11.x - various MacPro Towers - home system MacPro Dual 2.8 8core GTX680 "Harpertown"... [view my complete system specs]
    Jef Huey
  • Tue, Oct 16 2018 5:20 AM In reply to
    soloed works. thanks... subclip sure. Just dont understand that quiktime setting then ... selected tracks
  • Tue, Oct 16 2018 5:25 AM In reply to
    yes I know that... sucks though. Talking to Boris FX too. currently there's no way to fix that. Also Boris FX Title Studio doesnt export. The suggest that the posthouse get a copy of Boris FX themselves :-)  before you make final mixdown
