Latest post Fri, Oct 12 2018 8:41 PM by Marianna. 3 replies.
  • Thu, Oct 11 2018 1:56 AM
    • amythystj
    • Joined on Thu, Oct 11 2018
    • Posts 2
    • Points 30
    failed install? "The application Avid Media Composer has quit unexpectedly"
    When I realized First wouldn't do what I wanted, I decided to test out the trial. Initially I forgot to uninstall First, and Media Composer wouldn't download. So I clicked the uninstall folders, then installed Media Composer and thought everything was fine. But it won't open. I have a MacOS, 10.13.6, in good condition (knock on wood).
    I tried uninstalling, restarting, and reinstalling. I tried opening the FatalError folders but when I opened the documents, they appreared to be blank.
    Just now I found 2 folders in Applications Support with Avid file names that I'm deleting, and any other files I can find with "Avid" in the name.
    Is there anything else you suggest?
  • Thu, Oct 11 2018 5:22 PM In reply to
    • Posts 9,775
    • Points 212,525
    Re: failed install? "The application Avid Media Composer has quit unexpectedly"
    Amythystj
    Try the following:
    Delete the folder in bold below:
    HD/Library/Caches/Avid/AppManager/Cache
    HD/Library/Caches/Avid/AppManager/Db
    HD/Library/Application Support/Avid/Licenses
    Now try it
    marianna
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Oct 11 2018 11:52 PM In reply to
    • amythystj
    • Posts 2
    • Points 30
    Thanks for the suggestion! I looked in those places and in others (like preferences) and deleted whatever AVID files I could find. Then I downloaded it again and it restarted my computer. The Media Composer sent a message about downloading something else, I did. Then I opened it. AND... I got the same message.
    If you have additional suggestions, that would be awesome.
    If not, I may just be part of Download-Darwinism: survival of the fittest.
  • Fri, Oct 12 2018 8:41 PM In reply to
    • Posts 9,775
    • Points 212,525
    what EXACT OS?  what Exact computer specifications?  And where did you install MC - internal drive - external drive etc..
