Latest post Wed, Oct 10 2018 12:20 PM by scocklin. 3 replies.
  • Tue, Oct 9 2018 9:03 AM
    • Liliana
    • Joined on Wed, Apr 12 2006
    • FL
    • Posts 32
    • Points 410
    Sticky Playback in 2018.8
    I have NEVER had this issue with any version of Avid going back to 1998. I am editing and playback of the timeline is sticking and will then catch up to itself. This is in draft mode thru full green playback mode. It happens while playing back a timeline or in Full Screen Playback mode. It also happens when I mix down the sequence.
    I have done nothing different with this laptop except upgrade the software.
    Why is this happening? It's pretty bad trying to tell a client that the stutter really isn't in the sequence once it's encoded out.
    HP Zbook 17 G3 Mobile Workstation, Intel Core E3-1535M Quad Core 2.9GHz, 32GB RAM (4x8GB), 1TB 7200RPM HDD, M4000M Video - 2018.7, BCC Also have old Mac... [view my complete system specs]
  • Tue, Oct 9 2018 12:19 PM In reply to
    Re: Sticky Playback in 2018.8
    What resolution? what storage drive (and how is it connected)?
    What OS are you running?
    Avid is continually adding more and more functionality and that has a hit in terms of the demands of the system as well as the OS.
    The new live timeline means more resources are needed. YOu may have reached the cliff edge for your system.
  • Tue, Oct 9 2018 3:23 PM In reply to
    • Liliana
    • FL
    • Posts 32
    • Points 410
    I use Windows 7: HP Zbook 17 G3 Mobile Workstation, Intel Core E3-1535M Quad Core 2.9GHz, 32GB RAM (4x8GB), 1TB 7200RPM HDD, M4000M Video - 2018.8
    I have a WD my passport hooked up to the laptop for media as usual.
    I imported HDV footage which converts to MXF. Basic resolution 1920x1080 MXF. Nothing heavy just a few push effects, some BCC wipes. I'm thinking maybe rolling back to 2018.1? Or maybe even back farther.
    Being onsite in a hotel room with clients looking at the edit...this is not encouraging.
  • Wed, Oct 10 2018 12:20 PM In reply to
    • scocklin
    • Maryland
    • Posts 655
    • Points 7,855
    Pat Horridge:
    I have had the same problem with a time line heavy in effects (spectra matte and fluid morphs) turning clip frames off and reducing the video quality menu to half speeds things back up.
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
