Latest post Fri, Oct 5 2018 11:06 PM by jwrl. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Oct 5 2018 8:42 PM
    Deleting an effect between two other effects...
    Example:  You have a short clip with disolves on either side and a resize in the middle.  I want to delete just the resize but Avid will ALWAYS delete one of the dissolves first meaning that if I want that resize deleted I have to delete and then reapply the dissolve. Not a huge deal but over time this becomes very tedious.
    Could there not be some sort of pop up which asks which effect you want to delete?
    Andi
    HP Z400 Quad core 2.66 GHz Nvidia Geforce GTS250 1GB 16GB RAM 128GB SSD boot drive M Audio Audiophile 192 soundcard 2x KRK Rokit RPG2 powered monitors... [view my complete system specs]
  • Fri, Oct 5 2018 11:06 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,372
    • Points 96,860
    Re: Deleting an effect between two other effects...
    You already can control that.  Enable segment mode and click on the section of the timeline that you want to remove the effect from.  Click remove effect and you're done.
