I've been doing some tests and filming a person speaking within a bandstand. While essentially outdoors, the bandstand creates an echo and I wondered what is a good recommendation for an audio plug-in?
Thank you,
DC
I presume you want to remove the echo? IZOTOPE RX has a good module to reduce reverb/echo from a recording.
IZOTOPE RX www.izotope.com they have a trial which fully works.
https://www.izotope.com/en/learn/products/rx/reducing-reverb-with-the-rx-de-reverb-module.html
Hope that helps.
Leo
Thank you, though I was hoping for a recommendation from the existing suite of plug-ins within MC? I've bust my budget lately.
They just have eq and compression. Maybe eq put at tail end of the echo but it won't be perfect. You can use the trial to get the work completed using Izotope.
