Latest post Tue, Feb 5 2019 8:04 PM by BenoitM. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Oct 2 2018 10:23 PM
    • DaveS
    • San Diego, CA
    • Posts 222
    • Points 2,675
    Two Avid Generic Plug-Ins competing to link A7s footage
    On a client's Symphonies. They recently updated from 2018.7 to 2018.9. Now it seems there are two Avid Generic Plug-Ins installed - 2.6.0.10041 and 3.3.4.10092. When linking in a card's worth of A7s footage, half of them are using the new Generic Plug-In (and showing timecode) and the other half are using Avid Generic Plug-In 2.6 (00:00:00:00). RT-Click on the clips when linking only shows one Generic plug-in (plus QuickTime and XDCAM plug-ins) but there's no distinction between 3.3 or 2.6.
    How can we get rid of the older 2.6 plug? I don't see an uninstaller for it. Prior to the update to 2018.9 they uninstalled Avid Media Composer and Avid Application Manager, but left Avid Codecs PE. Does that package need to be uninstallled as well before an update?
    HP z800, Windows 7 64 sp1
    Mid 2014 Retina MBP 2.5 i7 w16 GB RAM. Running MC Symphony 2018 with PhraseFind! High Sierra 10.13.6. OWC Thunderbolt dock, 2xSSD Akitio Thunderbolt enclosure... [view my complete system specs]
  • Wed, Oct 3 2018 4:01 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,590
    Re: Two Avid Generic Plug-Ins competing to link A7s footage
    I'm pretty sure that you're using the latest version. The easy way of tersting is to take something that has timecode and link to it. If you get timecode out, you're using the new version. Unfortunately, there's no documentation as to where the Avid Generic Plug-in is stored (I suspect it's in the Editor Transcode directory somewhere).
    Dave S.
  • Wed, Oct 3 2018 7:32 PM In reply to
    • DaveS
    • San Diego, CA
    • Posts 222
    • Points 2,675
    Thanks. The odd thing here is that upon importing (linking) to the footage in Premiere CC2017, all clips show timecode. But using 2018.9 results in some clips showing timecode and some not, based on the Avid Generic Plug-In that gets associated to the clip in the source browser.
    Some clips have TC
    And I can't see any reason some clips get to use the new Generic Plug-In (3.3.4) and some get the timecode-ignorant 2.6.
  • Thu, Oct 4 2018 10:34 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,623
    • Points 60,385
    Were the clips linking with 2.6 used in a previous version of Media Composer? I think MC tries to continue using the same plugin that was used originally to link a particular source file. Probably stores this in the AMA cache. Just a guess - could be totally wrong here.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Oct 4 2018 6:58 PM In reply to
    • DaveS
    • San Diego, CA
    • Posts 222
    • Points 2,675
    Nope. Card had just come in from the field.
    But AMA Cache is a lead I'll take. Perhaps all the previous imports to A7s footage mentioned in the cache have informed the new software. Will try clearing the cache. But if that doesn't do it I'm thinking I'll suggest a full uninstall/reinstall...
  • Fri, Nov 9 2018 10:35 PM In reply to
    • Joe
    • Joined on Tue, Nov 9 2010
    • Mamone
    • Posts 8
    • Points 90
      Avid Certified User
    I'm getting the exact same issue! did the clearing the Cache work? I'm on Windows 2018.8.
    • Joe
    • Mamone
    • Posts 8
    • Points 90
      Avid Certified User
    Did the clearing the Cache work? I'm on Windows 2018.8.
  • Fri, Nov 9 2018 11:19 PM In reply to
    • DaveS
    • San Diego, CA
    • Posts 222
    • Points 2,675
    No, I'm sorry Joe.
    I cleared cache but it didn't help. Uninstalled the full app and reinstalled - to no avail.
    I dug into the Program Files/.../AVX2_Plug-Ins/AMA folder, found and deleted the Q7-2.6 folder, leaving the Q7 by itself, but can't launch into MC until the Avid installer is finished putting back the Generic 2.6 for me!
    So Avid support got back to me with word that this behavior has been officially logged as a bug, and to watch update release notes to see when it has been fixed. 2018.10 came but it wasn't in the release notes.
    As of right now, whenever A7s FTG comes in, it gets transcoded to DNx QTs in Adobe Media Encoder, which are then consolidated onto the Nexis - with timecode.
    Good Luck!
    Joe:
  • Tue, Feb 5 2019 8:04 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,189
    • Points 14,250
    This is still an issue with 18.12
    Worse: when I moved external drives from USB to NAS (and mounted them using the same drive letters), some of previously linked MP4 AVC AMA clips relinked using the "old" plug-in and some the "new" one, apparently randomly. The bad consequence is that previously created group clips are now broken (clip duration differ by 1 frame depending on the plug-in used [:'(])
    MC 2018.12.1 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (11.0.0.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz -... [view my complete system specs]
