Latest post Thu, Oct 11 2018 6:41 PM by Marianna. 3 replies.
  • Tue, Sep 25 2018 9:01 PM
    • Doug Abel
    • Posts 26
    • Points 310
    ProTools | Control (iPad) and MC 2018.9 won't play together
    OK, I'm just nerdy enough to want to try this, but I have my expectation phaser set to "low."
    I downloaded the latest ProTools Control (v18.3.0) from the app store for the iPad and downloaded and installed the latest from the avid download center (Eucontrol 3.7 mac).
    When I try to link the two on the MC end it says PT | Control cannot be added bc it is not compatible with the installed version of EuControl.
    Tried reinstalling each, no dice. Website says it should work.
  • Wed, Sep 26 2018 2:57 PM In reply to
    • carlone
    • Los Angeles
    • Posts 147
    • Points 1,900
    Re: ProTools | Control (iPad) and MC 2018.9 won't play together
    I went through this too.
    It was my version of EuControl. You need to find EuControl 18.3.0 - I think I found this version from the Avid S6 EuCOntrol installer (not sure about that). But I'm looking at v18.3.0.244
    Hope this helps
    MC Soft 3.1 on Mac 8 core (6 gigs of ram) MC Soft 3.0 on Macbook Pro (3 gigs of ram) Pro Tools 8 HD or LE installed on both computers [view my complete system specs]
  • Wed, Oct 10 2018 8:44 PM In reply to
    • Doug Abel
    • Posts 26
    • Points 310
    You are correct! Works now. The download ccenter needs to be fixed so this is easier to find.
    I found it at:
    http://esd.avid.com/ProductDownload.aspx?id=1902
    Downloaded EUCON 2018.3 (Mac)
    And when I ran the installer, I only checked the first box.
  • Thu, Oct 11 2018 6:41 PM In reply to
    • Posts 10,087
    • Points 216,565
    Doug
    Will alert the DL center team to this.
