Latest post Wed, Oct 24 2018 3:50 PM by loki. 4 replies.
  • Wed, Sep 19 2018 1:34 PM
    • george777
    • Joined on Sat, Jul 30 2011
    • Italy, Roma
    • Posts 31
    • Points 450
    subcap subtitle export for Vimeo
    I've made subtitles to a film using subcap. Than I've exported them in both .txt and .stl.
    The problemis I can't find a way to apply them on Vimeo. I know that Vimeo supports .vtt and .srt, so I've converted my subtitles using a few online tools (http://www.nikse.dk/SubtitleEdit/Online  and https://gotranscript.com/subtitle-converter). But my converted files don't work on Vimeo. I can't figure out why. I've even tried to convert them in UTF-8, following Vimeo guidelines, but with no results. I guess Avid subcap export has some problems.
    I'd really appreciate any kind of help because I'm going crazy.
    Thanks!
    Media Composer 8.2 Mac OS X 10.9.5 Mac Pro 2014 Dual Six Core 3,g ghz, 32GB 1867 mhz ddr3 ram. AMD FirePro D500 3072 Mb [view my complete system specs]
    Filed under: , ,
  • Fri, Sep 21 2018 3:37 PM In reply to
    • Rick Rose
    • Toronto, ON, Canada
    • Posts 61
    • Points 755
    Re: subcap subtitle export for Vimeo
    I'd like to know too. :) Avid MC 8.8.5
    OSX 10.10.5 Yosemite, Avid 8.8.5, Quicktime 7.6.6 Mac Pro 3,1 12 Gig Ram, ATI 5770, E4P eSata card [view my complete system specs]
  • Fri, Sep 21 2018 4:04 PM In reply to
    • Rick Rose
    • Posts 61
    • Points 755
    Ok, I got it to work for me on Vimeo.
    Export subcap file as .txt
    Open Text editor / notepad - my start timecode was set to 01:00:00:00.
    Change that to start at 00:00:00:00, and change all captions to start an hour earlier.
    Go to this site:
    https://transcribefiles.net/other/pages/caption-subtitle-converter.htm
    Upload file, and convert to .srt
    Download that file, rename it something reasonable (It comes out with a really long name).
    Upload to vimeo.
    It will work.
  • Fri, Sep 21 2018 5:20 PM In reply to
    • george777
    • Italy, Roma
    • Posts 31
    • Points 450
    Thanks Rick,
    that was the exactoly the problem. I've discovered that last night, but instead of manually change all my
    in and out point in the .txt, I've duplicated the sequence,  cut my counter and everything before the start of my film (it was 1:00:00:00). Than I changed the starting timecode on my timeline to 00:00:00:00 and I've exported my subtitles in .txt. and converted it in .vtt from this website: https://gotranscript.com/subtitle-converter
    Now, my Vimeo subs work fine.
  • Wed, Oct 24 2018 3:50 PM In reply to
    • loki
    • Joined on Sat, Mar 17 2012
    • Posts 27
    • Points 325
    Thanks for the online converter! Works like a charm.
    For anyone using the export caption data, a little warning if you use disabled (invisible) subcaps on your timeline:
    Disabled subcaps may appear in your text file and be visible on Vimeo!
    I didn't inspect this issue further, but at least two disabled subcaps from the timeline got added to the txt file at 00:00:00:00 as visible captions. May also have something to do with subcaps sitting on various tracks, dunno. I just deleted these disabled subcaps (which were prepared for a specific case that did not happen) and the file is fine.
    MC 8.8.4 OSX 10.12.4 MacPro 6,1 [view my complete system specs]
