Latest post Mon, Oct 22 2018 8:06 PM by palm. 64 replies.
Page 3 of 5 (65 items) < Previous 1 2 3 4 5 Next >
  • Sat, Oct 6 2018 7:13 AM In reply to
    • gstrudler
    • Portland, OR
    • Posts 27
    • Points 375
    Re: Media Composer 2018.9 - launched today 9/14/18
    Nitris DX interface hasn't worked since 2018.7; MacOS 10.13.6. Works on MC 2018.5, but nothing later; very repeatable.
    I have a support case open (have since 2018.7 release), but curious if others have run into this? I know the DX interfaces are getting a bit long in the tooth, but they are still technically a supported configuration.
    Based on some of the conversations about AJA devices having issues around the same time, I'm guessing something significant in the I/O architecture changed in the 2018.7 release?
    MacOS 10.13, Media Composer 2018, Pro Tools 2018, 12-core Ivy Bridge Mac Pro, dual AMD D700, 64GB RAM, SSD system drive, 2-drive RAID 0 media drive, Nitris... [view my complete system specs]
    Filed under: , , ,
  • Sat, Oct 6 2018 6:27 PM In reply to
    • Michaelk
    • Posts 5
    • Points 55
    DPx export is brooken! The exported file has dropped framed and duplicated frames. If you export a minute you get a minute back but it has drooped frmaes and then others duplicted to make up th diffrnace.
    This is also still brooken on 2018.10 that I'm testing. Please fix this
    Media Composer 2018.9 Windows 10 pro. HP z840 128gb ram. 2 GeForce GTX TITAN X. Dual fiber card connected to SAN. [view my complete system specs]
  • Mon, Oct 8 2018 9:42 AM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Posts 53
    • Points 710
    Hi Marianna,
    is there any chance to get that beta-version, too? 2018.9 is so incredibly not working on a fresh 2017-MBP (MacOS 10.13.6., latest AJA-Software) but I had to see it with my own eyes. ;) Rolled back to 2018.5, works fine now. But I was looking forward to using some of the new 2018.9 features.
    Thx :)
  • Mon, Oct 8 2018 2:48 PM In reply to
    Hi Marianna,
    Same issues with AJA here.
    I've mailed you to see if I can get hold of the Beta too.
    Nik
  • Mon, Oct 8 2018 3:17 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hey you can email me direct and I can send it but not until tomorrow.  Holiday here in the States.
  • Mon, Oct 8 2018 5:20 PM In reply to
    gstrudler:
    We are using the Nirtis DX with the latest MC versions on El Capitan.
    Are you including the DX driver when you install MC? A while back that became an optional installation and must be manually included.
  • Mon, Oct 8 2018 6:35 PM In reply to
    • gstrudler
    • Portland, OR
    • Posts 27
    • Points 375
    Kevin Klimek:
    Yes, manually checking the DX driver install; have to do this for 2018.5 as well, which is working fine. Have tried it on both a Westmere Mac Pro (no longer officially supported) with PCIe card and an Ivy Bridge Mac Pro with Sonnet adapter; same result on both: works on 2018.5, but not on 2018.7 or later. However both installs have been on High Sierra; interesting that it works on El Capitan though.
  • Tue, Oct 9 2018 8:47 PM In reply to
    • DonE
    • Joined on Tue, Aug 18 2009
    • California, USA
    • Posts 77
    • Points 930
    gstrudler:
    We are using Nitris DX on a Mac Pro (mid2012) PCIe with 10.12.6 and 2018.9. It worked with .7 and .8 also.
    Don
    1x AMC/Sy 8.2.11-Win7 Pro 64-HP z800-dual 6core-24GB-Quadro FX 4800-Nitris DX QT775 NV340.84** 3x AMC/Sy 8.2.11-Win7 Pro 64-HP xw8600-8GB-Quadro FX 3700... [view my complete system specs]
    • Posts 10,079
    • Points 216,475
    Cutyes:
    Hi Marianna,
    Thx :)
    Sending it now.......
  • Tue, Oct 9 2018 8:48 PM In reply to
    • Posts 10,079
    • Points 216,475
    Nik Hindson:
    Hi Marianna,
    Nik
    Nik
    You have the files by now.
  • Tue, Oct 9 2018 9:09 PM In reply to
    • gstrudler
    • Portland, OR
    • Posts 27
    • Points 375
    DonE:
    Don
    Good to hear; thanks. At this point it's sounding like either it's me somehow or High Sierra as the issue then. Since I can get it to work reliably on two different machines under 2018.5, however, I'm leaning towards macOS 10.13 being the issue...
  • Tue, Oct 9 2018 9:25 PM In reply to
    Make sure you allow the drivers to be activated in System Pref - > Security and Privacy. If you don’t, after a certain period is will disable the drivers.
  • Tue, Oct 9 2018 10:42 PM In reply to
    • gstrudler
    • Portland, OR
    • Posts 27
    • Points 375
    Dom Q. Silverio:
    I have, but thanks for the reminder; I even verified in Terminal that the kext is currently loaded. For grins, can someone with a functioning DX run this command in terminal and let me know what version of DX driver you get?
    kextstat | grep -v com.apple
    I'm showing: com.Avid.driver.AvidDX (5.9.3).
    Sorry to thread-jack, but appreciate the help.
  • Wed, Oct 10 2018 2:26 AM In reply to
    • gstrudler
    • Portland, OR
    • Posts 27
    • Points 375
    Quick update: support was able to recreate the same issue, so I'm glad I'm not going totally crazy!
  • Wed, Oct 10 2018 10:24 AM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 139
    • Points 1,710
    Does anybody tried MC beta with AJA?
    How this pair works?
    MacBook Pro (Retina, 15-inch, Mid 2014), 2,8 GHz Intel Core i7, NVIDIA GeForce GT 750M 2048 MB, OSX 10.11.6 [view my complete system specs]
