Latest post Fri, Sep 7 2018 10:35 PM by chuckkahn. 2 replies.
  • Fri, Sep 7 2018 2:52 PM
    • chuckkahn
    • Toronto
    • Posts 338
    • Points 3,770
    Eyedropper in v18.4 not working
    Eyedropper isn't working.  Just creating a simple rectangle in Paint Effect for example, I position the pointer over the Color Preview to activate the eyedropper, but when I click the mouse button the eyedropper deactivates (becomes the arrow pointer) and the Color Info window appears, which previews the color the pointer is hovering over, but when I click on the color I want, nothing updates.
    This was in version 18.4.  So I updated to 18.8.  Same.  Another Avid on 18.4 two doors down couldn't do it either.  Another Avid running 8.4.5 could do it.   Installing 8.9.4 to see if the same happens.
    Update: Doesn't work in 8.9.4 either.
    Update: Doesn't work in 8.9.2 either.
    Update: Doesn't work in 8.8.5 either.   Is it an OS 10.12.6 thing?
    Update: Works in 8.4.5, but only samples from the record monitor.  Not the source or pop-up monitors.
    Avid Media Composer 2018.11 / Mac OS Sierra / MacPro5,1 / 6-Core Intel Xeon 2.66 GHz x2 / 64 GB 1333 MHz DDR3 ECC [view my complete system specs]
  • Fri, Sep 7 2018 9:33 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,792
    • Points 19,770
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Eyedropper in v18.4 not working
    Hi chuckkahn,
       Please email your Avid MC systems ID, I will open a support case to get this investigated.
    RalphC
  • Fri, Sep 7 2018 10:35 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 338
    • Points 3,770
    So the Eyedropper does work in 2018.8, but not in the way I was expecting.
    1) The pointer icon flickers briefly as an eyedropper but reverts back to the arrow icon, so you don't know you're actually wielding an eyedropper.
    2) The range of what the eyedropper can sample is limited to within the record window.
