Latest post Wed, Sep 26 2018 8:54 PM by RalphC. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Aug 31 2018 9:38 PM
    • Conci1025
    • Joined on Fri, Aug 31 2018
    • Posts 1
    • Points 20
    Unable to launch AVID
    I recently downloaded "Media Composer | First" onto my computer. When I tried to launch AVID, I received a notification saying "Segmentation fault" in thread "MainThread", at address    0x0".
    Has anyone else experienced this issue? if so, how were you able to correct the problem?
    Here are the computer specs that I'm using.
    macOS High Sierra Version 10.13.4
    Processor2.3 GHz Intel Core i5
    Memory16 GB 1600 MHz DDR3
    GraphicsIntel HD Graphics 3000 512 MB
  • Tue, Sep 4 2018 2:08 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,666
    • Points 18,295
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Unable to launch AVID
    Hi Conci1025,
      Take a look at this FAQ
    RalphC
  • Tue, Sep 11 2018 1:55 AM In reply to
    • dirwuf
    • Joined on Mon, Sep 10 2018
    • Posts 3
    • Points 45
    I have same issue as OP, with a newly formatted Macbook Pro that has successfully run MC before. I've reinstalled twice and tried the above workaround with no success.
  • Tue, Sep 11 2018 2:26 PM In reply to
    • Posts 9,804
    • Points 212,910
    dirwuf...
    Is the new Mac Pro on OS 10.13.6?  MC First 2018.8?
    Anything else installed????
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Sep 12 2018 11:14 AM In reply to
    • dirwuf
    • Posts 3
    • Points 45
    Yes, MC First 2018.8 on 10.13.6, but it's an older MacBook Pro that I reformatted...nothing else installed. Note, it has run MC before.
    Video of end of bootup
    MacBook Pro (13-inch, Late 2011)
    2.4 GHz Intel Core i5
    8GB 1333 MHz DDR3
  • Sun, Sep 23 2018 10:08 PM In reply to
    • Conci1025
    • Posts 1
    • Points 20
    Hi Ralph,
    I tried this work-around and it didn't work. Is there another solution for this issue that I can try?
    -Cole
  • Mon, Sep 24 2018 2:54 PM In reply to
    • Posts 9,804
    • Points 212,910
    dirwuf:
    8GB 1333 MHz DDR3
    Thanks for the screen shot.  Now i know what is going on...
    The Settings file of Media Composer are corrupted and they need to be refreshed.
    In Order to refresh them go to :
    MAC :
    /Applications/Avid Media Composer/Settings       and Rename the Settings folder.
  • Tue, Sep 25 2018 9:32 PM In reply to
    • ChrisMD
    • Joined on Tue, Sep 25 2018
    • Posts 2
    • Points 30
    I'm having the same issue. What do you mean "rename the settings folder"? I renamed it to 'xSettings' so it wouldn't be recognized by MCFirst, but I'm still getting the error message.
  • Tue, Sep 25 2018 9:50 PM In reply to
    • RalphC
    • Posts 1,666
    • Points 18,295
      Avid Employee
    Hi ChrisMD,
       Can you check the permission settings?
    1. Click on your system drive (Macintosh HD in most cases) to highlight.
    2. From the File menu select Get Info (cmd+I).
    3. Click the lock icon in the bottom right to make changes
    4. Click on the “Read-only” text in the Privilege column next to Everyone and set the privilege to “Read & Write”
  • Wed, Sep 26 2018 8:40 PM In reply to
    • ChrisMD
    • Posts 2
    • Points 30
    That changed my permissions, but didn't allow the software to launch. Still get the same Segmentation error. Again, first time launching MCF.
    System is:
    Mac OSX 10.11.6
    Processor 2x2.8 GHz Quad Core Intel Xeon
    8gb Memory
    Graphics ATI Radeon HD 2600 XT
  • Wed, Sep 26 2018 8:54 PM In reply to
    • RalphC
    • Posts 1,666
    • Points 18,295
      Avid Employee
    Try to uninstall reinstall since the permission has changed.
    RalphC
