I have MXF files - AVC Long-GOP High422 (HD720p).
They are crashing my system. Do I need a specific ama for this?
Need the standard info: What version of MC? What platform, what OS? How much ram? We have ony started supporting this resolution in 2018.6
OS 10.13.6
i mac pro
10 core
128 GB Ram
Vega 64
Avid Medi Composer 2018.8
Getting that DEBUGGER/EXIT APPLICATION ERROR WHEN I TRY TO PLAY THESE CLIPS.
And have you downloaded the latest Panasonic AMA Codecs? I am sitting in front of 8 Media Composer systems playing this codec right now. We did AMA>Consolidate though.
The other thing you have to worry about with High Sierra are the read/write permissions and exra security involved in a mounted AMA volume. Are you able to AMA>Consolidate?
Is this the one?
http://avid.force.com/pkb/articles/en_US/Download/en394531
I always check avid.com/ama as those are the latest
Thats where that link came from. Just making sure it's the right one to play this sort of file type...
Yep. That's what I am using. I am betting this is a file path/permissions issue in the OS. What happens if you try to consolidate from a mounted AMA volume?
And...you do have the AMA license for Long G from Panasonic..right? It is required. Write back to P2 is a second license
Spot on Todd! My bet too.
In laymens terms, what exactly do I need to do to solve this issue?
If you haven't purchased the AMA licenses from Panasonic, I would start there.
Dumb question, but I cannot find the link to where you can buy this Panasonic AMA for Avid. If anyone has the purchase link, that would help me out a lot. The client that provided the footage seems to think I need
Drastic Media Reactor ama Plugin
https://pro-av.panasonic.net/en/sales_o/p2/avidnle_ps/
Read thru and you will see what to do and select
marianna
