Latest post Wed, Sep 5 2018 12:37 PM by Roger Shufflebottom. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Aug 29 2018 11:16 AM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Has Marquee always been like this?
    Ive just created 50 plus animated titles in Marquee and having waited while they all render off into a bin in Media composer, I was surprised to discover that the still need rendering on the time line; the title all have blue dots. I was under the impression that as rendered effects they should play in realtime in the source monitor. Am I deluded of has something changed? (I ont use Marquee that often, so may be it's me)
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Thu, Aug 30 2018 6:23 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Re: Has Marquee always been like this?
    Answering my own question; no it hasn't.  I've just seen one of Kevin P McAuliffe's old tutorials on CrativeCow. He designed an animated title featuring extruded text, lighting moving it in 3D space; rendered it off and then, back in MC, he was able to play the title in the source browser. So what would stop that working on my system?  My animated titles go to the timeline with a blue dot.
    Puzzled!
    Matt
    Matt B
  • Thu, Aug 30 2018 6:31 PM In reply to
    • Posts 10,227
    • Points 218,320
    MattB:
    Sorry Matt - been a tad slammed the last 2 days.  youer spec's are great but which system is this happening on and what OS and MC version.
    I am going to go check a few things and come back and hope you answered.
  • Thu, Aug 30 2018 7:02 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Hi Marianna - thanks for reaching out. it's my 'edit 1' system which is MC 2018.5 on Windows 10 professional.
    Matt
    Matt B
  • Thu, Aug 30 2018 10:35 PM In reply to
    MattB:
    Puzzled!
    Matt
    Did you try it with Render on the Fly on?
  • Fri, Aug 31 2018 9:06 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Telegram!:
    I did and it is. Going to check behaviour on my other systems today and report.
    Matt B
  • Fri, Aug 31 2018 1:03 PM In reply to
    Not sure if this helps but until a few months ago, static Marquee titles were RT but animated ones were not, and showed a blue dot and needed rendering. Sometime in a 2018 release, I think, animated Marquee titles became RT. I'm on a Mac, however. Just tried one and it plays without rendering.
    iMac i5 27", 24GB RAM, OS 10.13.6 with Symphony 2018.12, BlackMagic mini monitor. MacBook Pro, 16GB RAM with OS 10.13.6 with MC 2018.5 and BMD Ultrastudio... [view my complete system specs]
  • Tue, Sep 4 2018 1:08 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Roger Shufflebottom:
    Interesting. I have three systems and I have now tested on all of them. My systems are called (imaginativley) Edit 1, Edit 2 and edit 3, reflecting the order in which I set them up. Edit 2 in a long-in-the-tooth system with a perpetual license for MC 7.6, the others are up-to-date.
    On all of my systems animated Marquee titles come into MC as blue dot effects; so I assume this is as it has always been so and that I have simply mis-remembered things. I rarely use Marquee for still titles, let alone animated ones.
    That doesnt explain how Kevin P. McAuliffe managed to demonstrate an animated title being previewed in the source monitor, but I cant make it happen that way.
    Matt
    Matt B
  • Tue, Sep 4 2018 3:10 PM In reply to
    Well, my system does now play them in the Source monitor and the Timeline, no rendering. It was a great surprise to discover this a few months back.
  • Tue, Sep 4 2018 5:35 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Well that's very curious and no mistake!  And which version of MC are you using?
    Matt B
  • Tue, Sep 4 2018 7:00 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Cymru/Wales
    • Posts 1,087
    • Points 13,400
    Animated Marquee titles always need rendering dont they (just like rolls/crawls)?  Static ones dont.  You got me wondering now!  You also cant keyframe them on the timeline.
    As an aside i have jumped many Avid versions to current version yesterday - I note the Marquee version number is updated too.  Please tell me it does 4k now?!  Spent too long learning it to bin it!!!
    Symphony 2018.2.3, Blackmagic Intensity Pro (grinds system to a stutter in full res 4k though for client monitor - which was the point...), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K2000, Asus X99 Mobo, 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 @ 450Mbs
    VIDEO MEDIA PRODUCTION COMPANY AND FACILITIES CARDIFF, LONDON, BRISTOL, WALES, CRACKING PRODUCTIONS
  • Wed, Sep 5 2018 12:37 PM In reply to
    Not any more, they don't. They show a green dot and play in RT. Nothing above 1920 HD, though. Your current option is the NewBlue Titler but Avid have announced a UHD Title Tool (not seen it, however and no date announced). I'd say that fior HD, it is worth learning Marquee but it can be a steep learning curve.
